(Topic ID: 290087)
Incandescents, SMDs, Heat etc.
By koji
  • 10 posts
  • 6 Pinsiders participating
  • Latest reply 3 years ago by koji
    #1 3 years ago
    I tend to run both, at some point, I will transition to SMD when I can get a nice fade effect similar to the OCD mod etc.
    But really, my point is about the heat.. a nice clean incadescent ain't so bad. I did some quick reading averages with a temp. gun on some bulbs of various conditions, and thought I'd share this.
    Moral of the story, check your bulbs when you are shopping out your PF etc. If they are burnt or discolored, toss them. If applicable, gap the bulbs away from your inserts and plastics. Don't get angry at people that maintain their machine with clean incandescents.. the key is maintenance.
    [edit] oh and the photos are:
    Bright multi SMD
    Clean no.47
    Clean no.44
    Burnt no.47
    Very burnt (AKA Death Star) no.44
    #2 3 years ago
    Interesting--I hadn't realized burnt bulbs ran so much hotter than clean bulbs. Big difference between 65'F and 113'F
    #3 3 years ago
    You know the really black ones get hot when you grab one with your bare fingers for sure! It's actually enjoyable throwing those in the trash can.
    #4 3 years ago
    Quoted from ForceFlow:
    Thank you, yeah, people seem to consider the 44s as killers, but from what I saw, it was not too much hotter than the 47. I expected more of a difference... (even given some variance due to materials etc.)
    #5 3 years ago
    Very interesting. Thanks for sharing.
    #6 3 years ago
    Can you do an LED retro type which presumably has less LEDs on it than the bright version?
    #7 3 years ago
    Quoted from slochar:
    One of the least bright ones equal to a #47 probably wouldn't read much different than an empty socket.
    #8 3 years ago
    Interesting! I thought it was just a hunch I had when removing blackened bulbs vs. good unburned bulbs. It definitely felt like the blackened ones have been running hotter, and I'm glad someone was able to confirm that. But those temperature differences are pretty extreme. I think there are two reasons for this. One, the filament is degraded in these high runtime bulbs causing more resistance and more heat. Two, the tungsten particles on the inside of the glass itself block the visible and infrared light from escaping effectively, causing the radiation to be reflected back to the inside of the bulbs. This results in a kind of greenhouse effect like what you get when you leave your car windows rolled up in the summer.
    #9 3 years ago
    Quoted from Crash:
    Yeah, that makes sense to me. I just got tired of the witch hunt on incadescents. I like my LEDs, but I also appreciate that it is fine to run clean incandescents.. If maintained properly, they should not damage anything.... and I'd imagine in home use, this would take a fair amount of time (generally), for them to reach this stage of burn (if they survive long enough).
    #10 3 years ago
    Quoted from frenchmarky:
    Yeah, IIRC, they are running about 80% or so more efficiently, so ~20% of the heat?
    This page was printed from https://pinside.com/pinball/forum/topic/incandescents-smds-heat-etc and we tried optimising it for printing. Some page elements may have been deliberately hidden.
