Hi everyone.
I have bought a ot of frosted 6.3v LEDs with a 44 bajonet base sold as "suitabe for Pinball machines" directly from China and finally got them. I know that that might not have been the best placce to purchase but basically ordered them a day after I got my first pin without knowing that shops such as Cometpinball actually have really goo prices and fair international shipping costs. I will buy from them in the future but have a general question ni regards to LED usage.
The LEDs I got work fine when replacing GI bulbs (except for the LEDs actually emitting less light than slightly dirty incandescents) but I fail to get them working in inserts. They are designed for around 6.3V, testing them with a lab power supply works perfectly at 6.3V, although they also work with 12V and only get slighty warm.
The LEDs require negative at the larger bajonet base and positiv at the bottom tip to light up. My first guess would be that the insert lights are wired in the opposite manner. Unfortunatey I cannot test that as I can only get the insert lights to test in a blinking fashion (on-off-on-off-...) which confuses my multimeter, so I cannot get a reading for the voltage and hence the polarity.
I have the same problem with both my W?D and JM machines...
Basicaly my question is: Changing incandescent bulbs to LED should be plug-and-play, right? Or do I have to adjust polarity and diode direction at the lamp holders? I will be buying from Cometpinball as the LEDs from China do not meet my expectations, but before facing the same problem again, which I guess I should not, I still wanted to briefly ask.
Thanks in advance.
