(Topic ID: 128702)
In a pinch, which fuse would you use?
By gweempose
8 years ago
  • 19 posts
  • 13 Pinsiders participating
  • Latest reply 8 years ago by thedefog
#1 8 years ago
One of the GI fuses blew in my TSPP. It was 100% my fault. I shorted the circuit while working under the playfield. Unfortunately, I don't have any 5A slow blow fuses to replace it with at the moment. In a pinch, which would be a better replacement, a 4A slow blow, or a 5A fast blow? Bear in mind, all the incandescent bulbs on that circuit have been replaced with LEDs.
#2 8 years ago
I would do 5A normal..
#3 8 years ago
It's ok to under fuse, but never over fuse
#4 8 years ago
Either would should work fine and wont damage anything.
#5 8 years ago
Quoted from 0geist0:
Thus, both of his choices would be fine.
#6 8 years ago
EDIT: agreed - either should be fine.
#7 8 years ago
A 4A SB will be fine,it will last without a problem with leds installed until you get a 5A
#8 8 years ago
Thanks, guys! I figured it was probably six one way, half a dozen the other.
#9 8 years ago
On a related note, where can one go to quickly pick up a fuse locally? I used to always rely on Radio Shack for stuff like this, but that ship has sailed. Would a hardware store be a good option? What sucks is that I have literally every other fuse under the sun except the one I currently need.
#10 8 years ago
You could try an auto parts store.
#11 8 years ago
I picked up 5Amp fuses at Home Depot in NJ.
#12 8 years ago
Auto Parts stores or hardware stores like Home Depot or Lowe's might have them depending on the location. The big issue with both is finding slow blows as the majority will be fast acting in stock likely at these places.
#13 8 years ago
Pop the 4aSB in there and forget about it. It won't draw more than 4A. If it does with LEDs in there, you've got other issues.
Rule of thumb is never use a SB somewhere that needs to be shut down immediately if there is an issue, like a logic supply (+5v).
The reason 5ASB are in the G.I. to begin with is to prevent the sudden inrush of current from the transformer on power-on from popping a FB fuse to incandescent bulbs. A FB breaks down over time from these spikes in power-on cycles. I think it was meant as a durability measure, no immediate harm in slowly powering off the G.I. section, as it runs on AC anyway, those fuses are solely there to protect the transformer, no rectification. The rectified sections need to pop off right away though, or they'll burn up the bridges and/or other parts.
Someone correct me if I'm wrong here.
#14 8 years ago
I agree with you 100%.
The FB fuse will blow sooner than later in that circuit if you leave it in.
4A SB will last just as a 5A with leds,may as well leave it in.
-3
#15 8 years ago
Quoted from gweempose:
A Mod who doesn't know where to get a fuse?....OMG.... Its been nice knowing you guys.
#16 8 years ago
Quoted from Elevatorman:
That is an interesting thought. That might mean that you could damage things because the load is less due to using LEDs. The original fuses might be oversized.
#17 8 years ago
Quoted from Det_Deckard:
How would you damage it? Basically you now have a circuit designed to handle 5 amps and it is no longer pulling that amount.
#18 8 years ago
Quoted from alexanr1:
If you have a short or something faults or fails, it would be cleared out quicker with more load and maybe won't without the incandescent lighting load. Ideally, your fuse should be set not at what your equipment can handle but slightly above your maximum load current. Switching to LEDs means there is more margin between your load and blowing the fuse.
#19 8 years ago
I thought about this too. My thoughts are if there is a short on the GI line, it'll pop a fuse just like it always does, regardless of LEDs or AC bulbs. The transformer secondary tap and power is what determines the amperage for your fuse selection, that is the draw limit you are protecting and do not want to exceed. You're solely protecting the transformer from burning up. So it will pop a fuse regardless of whether LEDs are the load or incandescent bulb with a short. Just because it is drawing less current for LEDs doesn't change the design of the transformer. The only difference is that with LEDs, they're all internally rectified, so they're a little harder to short out.
But yes, technically if you are using all LEDs, you could roughly calculate the draw and lower the fuse value accordingly. No need for 5a fuses when using LEDs. I'd imagine you could get away with 2 amp fuses in most cases. Depends on the voltage drop of the rectifiers used and resistor value, but I can't imagine single LED bulbs are drawing more than like 10mA each. At that rate, 200 bulbs would draw 2 amps. I dunno any games that have 200 bulbs in them that are always on.
$ 19.95
8,000 (Firm)
Cherry Hills Village, CO
$ 79.00
arcade-cabinets.com
YouBentMyWookie
$ 59.00
Sparky Pinball
YouBentMyWookie
Sparky Pinball
Trade
Machine - For Trade
Springfield, MO
$ 44.95
PinBoss Mods
8,500 (OBO)
Gainesville, GA
6,899 (OBO)
Sioux Falls, SD
$ 12.99
Daddio's 3D Printed Mods
$ 39.00
Sparky Pinball
$ 29.50
Playfield - Plastics
$ 50.00
Duke Pinball
$ 29.99
$ 16.00
arcade-cabinets.com
$ 22.00
arcade-cabinets.com
$ 165.00
Pixels Arcade Games
Filament Printing
$ 18.95
This page was printed from https://pinside.com/pinball/forum/topic/in-a-pinch-which-fuse-would-you-use and we tried optimising it for printing. Some page elements may have been deliberately hidden.
