DIY sound upgrades round 3
I was getting frustrated with the stock woofer muddling up the sound of the new back box speakers. If we don't address this now, I don't think any additional levels of improvements will make any sense. It's like trying to listen to a vocalist do a solo while garbage trucks drive around behind the stage...
We could try to help this by adding to a separate powered subwoofer that can live under the pin for around $150-$200. It'll give us better base and fill out the sound spectrum in the lower subwoofer frequency range. But I'm not sure this is a great option just yet. It's expensive and that stock woofer will still be howling away in the background.
It's time to throw down with a new bolt in sub-woofer.
Subwoofers present a challenge in a pin. First, it's by no means an ideal enclosure. Second, they are power hungry and require a lot of power to truly shine. Third, good subs get expensive fast.
I found a renewed JBL Stage 810 for $50. A pretty good price for a solid upper-mid level subwoofer. If this nice JBL didn't work, there is no hope for anything lower/cheaper making a difference. Plus, I'm bolting these in with no amplification or additional hardware of any kind. Take out the stock woofer and put this in its place, that's it.
So how did it go - Ohhhhhh Myyyyyyyy Myyy Myy... This did the trick and then some. The pin is now coming alive. The base is very tight and punchy, you can feel it in your hands. It also cuts off closer to 500-1k without any filtering. This means much less mid is being created less projection through the backbox. What does make it up the backbox is nice and crisp and doesn't interfere or compete with the backbox speakers.
Pro's - This is the missing piece needed to make upgrading speakers worthwhile. Once balanced with the backbox speakers they stayed that way through all volume levels. Even lower volume levels still gave that nice bass/punch feel. There is also a tactile feel that is delivered to your hands. When the shaker and the soundtrack sync up - it's like having a shaker on roids. It'll make you look at your machine and say "wow - that's different"
Con's - It is a power-hungry sub. Even though it's 4ohms, you will need to run it as 8ohm to be able to balance more evenly with the back box speakers running at 4ohm. Mounting is not a simple bolt in replacement. The bolts in the cabinet will need to be replaced with longer ones, as the lip on this JBL is really thick. Alternatively, it's possible to clamp it down from the inside with some screws and toe clamps.
Overall - Speaker upgrades may only be worth it if you also change out that crappy woofer. Once you do - it just opens everything up. With this setup we are still 100% bolt in. For about $115ish dollars invested it's an incredible bang for the buck improvement. Many people could stop here and be really happy.
Next up - I'll get back to testing some quality 5.25" speaker upgrade options.
