After I few games, I had to tweak the center spinner to turn freely as it as hitting the left rail and stopping short. Targets that don't position perpendicular to the playfield make me nuts, so I straightened out the Whiplash targets to get rid of them being pidgeon-toed.
I seemed to be getting some serious airballs on shots to the left ramp, which I think were being cause by the fit of the Monger plastic in the playfield cutout. The front edge was a bit high and the back edge a bit low. I think they were launching off the back edge of the cutout. I did not see anything that looked like an adjustment to the orientation of the Monger assembly to the playfield, so I took off the piece that the plastic attaches to and changed its angle a bit to fit the cutout edge a bit better. Still not perfect, but it seems to have fixed the airball problem.
This fit concerns me. I can see wear occurring like at the back edge of the boom balloon on CV and the Drak Trak on MB. Thinking about making a mylar protector for the edge of the cutout that help avoid this.
Has anyone else this less than perfect fit? Yes, I know this is pinball, but let's get it right. Has it caused a lot of wear? What, if anything, have you done with yours?
It would be good if the whole assembly could lower itself just a hair more, but the stop screws at the bottom have no more play in them before the carriage bottoms out against the lower switch. Pretty sure it is not a good idea to have the weight of the assembly resting on the switch. Funny that the tiny screws mounting that switch are inserted so that the their heads are almost inaccessible and not to the open side.
I may just shim the assembly under the playfield and then play with the stop acrews to get a better fit of the plastic in the cutout.
Dan
