A couple months back I posted about my Ironmonger toy getting stuck, which turned out to be the harness getting tangled with the piece attached to the motor that spins around and raises/lowers the toy. I have repaired my wiring from that mishap and taped all those wires together, but if I try to attach that harness with zip ties to the same place they appeared to be anchored before, it either puts the harness in a position to be snagged again or else impedes the toy from fully lifting onto the playfield. Is there a good way to route the harness to allow the Ironmonger free up and down motion without putting the harness into harms way? If you've got a good setup, I could sure use a pic if it wouldn't be asking too much. Thanks.
