(Topic ID: 246921)
I’m about to buy a lightly used Hobbit LE (moving advice)
By Gattiman
1 year ago
  • 27 posts
  • 21 Pinsiders participating
  • Latest reply 1 year ago by punkin
    #1 1 year ago
    Idk if this is the place to put this. What are must do’s for transporting a modern pin? I’m renting a 10’ uhaul so it will be covered and strapped etc. do I have to take the legs off or will it be fine to drive about 200 miles with it more or less put together just with the head strapped down and blanketed?
    #2 1 year ago
    Take the legs off, no telling what a turn can do. Put something between the head and glass.
    #3 1 year ago
    Also, you don’t need a 10’, a van will do if available
    #4 1 year ago
    Another vote here for taking the legs off. Hobbit is one of the heaviest pins ever made and I would limit the amount of stress on the cabinet due to turns / bumps that can occur when leaving the legs on. The Uhaul should have tie downs for straps that you can wrap around the game to secure it, use at least a couple and put something in between the strap and game to eliminate damage to the decals.
    Regular van will work too and probably be easier to load. For either method I would pick up a big role of plastic wrap from Home Depot. Fold the head down at the location you are buying it from (apply some cardboard between head and side rails to prevent damage to powdercoat), wrap the game with plastic wrap, and then remove legs to move it into the van / Uhaul.
    #5 1 year ago
    Pay someone to move it.
    It only weighs about 350 pounds.
    #6 1 year ago
    It is heavy as hell, bring 2 others if you can to help move it.
    #7 1 year ago
    I’ve rented a dodge caravan to move a pin. I usually use my wife’s Toyota Sienna. No need for a huge truck. Definitely the heaviest pin I’ve ever moved- Just take the legs off, put a protective layer when you put the head down, wrap in a protective plastic wrap to limit damage. Make sure you don’t forget the keys, legs, bolts etc. take the balls out too- don’t want them shaking around or getting loose
    #8 1 year ago
    Quoted from Goronic:
    My wife works out. I can deadlift like 340lbs even then I’m a little scared lol. She isn’t scared after I made her help me move a 240lb SVS subwoofer upstairs.
    #9 1 year ago
    Is it a local move?
    #10 1 year ago
    Quoted from Pinless:
    Is it a local move?
    From Dallas to north Austin. About 230 miles mostly a straight shot on the freeway
    #11 1 year ago
    definitely take off the legs....no need for a large van....fits in the back of most SUV's....that being said its a beast to move...need at least two able bodies.
    #12 1 year ago
    Quoted from Gattiman:
    I’m not sure if I’m more intrigued by ‘my wife works out’ or ‘240 pound subwoofer’...
    #13 1 year ago
    To add to what others have said, the most likely place for you to do damage to that machine when moving it is at the corners of the bottom of the machine. If you are moving it into a van or any vehicle with even a slightly uneven floor, you life will be 500 times easier with some cheap rollers. This will prevent the bottom of the machine from rubbing against the floor and getting caught on something like a seat attachment and taking a chunk out. I would recommend going to home depot, spending $4 on a 2" PVC pipe and having them cut into 3 pieces of roughly 40" each. When loading into the back of a vehicle like a van, put the machine on the rollers when sliding back then remove the rollers before driving.
    Here are the steps I use:
    -Use a dolly with big inflatable wheels if you have to move through grass... a refrigerator dolly will sink
    -Remove balls, tilt bob, coin box, and other loose items inside machine before moving.
    -Fold down top box, and strap to cabinet leaving cardboard or blankets in sensitive areas.
    -Pick up rear of machine and slide a bar stool under the rear of machine
    -Remove rear legs and LABEL for next owner.
    -Gently set rear of machine on ground.
    -Tip machine onto it's bottom.
    -Slide dolly under bottom of pinball machine, with handle between legs.
    -Strap pinball machine to dolly (with lots of padding)
    -You can now hold the machine by the dolly or by the legs when moving.
    -If you need to rest you can rest the machine on it's front legs/dolly wheels while moving.
    -Wheel machine to vehicle.
    -Rest machine on dolly wheels/front legs.
    -Remove straps keeping machine on dolly
    -Lift rear of machine into rear of vehicle (with padding).
    -Push machine into vehicle until you can let go.
    -Remove front legs.
    -Label front legs.
    -Secure pinball machine.
    -Do steps in reverse at final destination.
    -Pinball!
    I got stuck in the mud a while back but this picture should give you a good idea on how to move a heavy pin. You do not want to just pick up a Hobbit like it's a coffin.
    #14 1 year ago
    I don’t understand why you put the rear of the pin in the vehicle first? I put the front( coin door) in first so that it can slide out and onto the ground/ dolly. Maybe I read your post wrong?
    #15 1 year ago
    Quoted from Budman:
    When I move a pin my dumbass is doing it by myself. You always put the back bottom of the pin on the bottom of the dolly as shown in the photo above. When you get it to your vehicle, you can remove the strap holding the pin to the dolly, lift up and slide the back end of the pin into the vehicle first, with the legs resting on the ground. You can then reposition yourself and slide the pin in all the way to the front legs, remove the legs, and then slide it the rest of the way in. This makes it easier to move the pin on the receiving end if you are using the same method, and has the added bonus on having the back of the pin at the front of the vehicle. The most likely way for the pin to slide is forward when you hit the breaks. It is much better for the pressure to be on the pack of the machine as opposed to the front where a plunger may be.
    I also find it much easier to move a pin on a dolly with the front legs on, but I have to navigate my machine up and down a hill. I maintain the ability to set the pin down and rest if I leave the front legs on, and it is much easier to maintain balance on uneven terrain with the front legs on.
    *As shown in picture, don't try and drag a pinball machine up a muddy hill.
    #16 1 year ago
    No reason you can’t leave the legs on. People ship legs on all the time with STI/beltmann. My 450 pound WOZ and JJPOTC shipped legs on no problem. Just strap it to the side nice and secure with blankets all around to protect it.
    #17 1 year ago
    Quoted from PinballSTAR:
    https://www.svsound.com/products/pb-4000?gclid=CjwKCAjwmZbpBRAGEiwADrmVXj6soELnjqgJ4FEO9e1Rq77GmwI2RRpXHpoK3ICfA2o4LfxCSkZrIBoCQY8QAvD_BwE
    It’s the best subwoofer I’ve ever personally heard. Tight earth shaking bass for movies. It will make your home better than a movie theater.
    And the wife lol.
    #18 1 year ago
    And the wife lol.[quoted image]
    You Sir have done well for yourself.
    Enjoy the new game!
    #19 1 year ago
    Another vote to not remove the legs.
    #20 1 year ago
    Your wife is 10000x more impressive than the Hobbit pin
    #21 1 year ago
    Quoted from cscmtp:
    We’ve been friends for 15 years and she was really over weight (like 200lbs) and I started training her over the years she’s down to 110lbs. This is her 14 years ago. Everyone can change! It’s amazing lol
    #22 1 year ago
    Take the legs off.
    And remember to use your legs; not your back.
    #23 1 year ago
    You and your wife need to write a book on weight loss/physical training, or open your own gym. You will make enough money at that to pay some other sucker to move your machines! Your wife's transformation is nothing less than astounding! Congrats to her for all her hard work and determination!
    #24 1 year ago
    I'd also get some heavy moving blankets. A large roll of plastic wrap is also good to have. Buy a moving dolly and straps if you don't already have them. Also, be sure to take the balls out!!
    #25 1 year ago
    Leave front legs on when moving...wow kids today
    Load the back of the machine in the vehicle first...wtf is going on these days?
    #26 1 year ago
    Better off renting a minivan if it’s a possibility.
    #27 1 year ago
    Quoted from Floyd:
    My Hobbit arrived balls in, so to speak. There is a flap that drops down with gravity to block the balls being able to be released from the machine? Is it that this should not be relied on?
    $ 29.95
    Pinball Photos
    $ 48.00
    $ 68.50
    pinballmod
    $ 89.99
    $ 160.00
    Id Rather Play Pinball
    $ 49.99
    € 3.70
    Buthamburg
    $ 19.99
    € 59.80
    Lighting - Backbox
    Freddys Pinball Paradise
    $ 154.00
    $ 27.99
    Lee's Parts
    $ 200.00
    Professor Pinball
    $ 5.00
    $ 12,500.00
    $ 74.00
    $ 7,999.00
    Nitro Pinball Shop
    $ 199.00
    Pixels Arcade Games
    £ 50.00
    Cabinet Parts
    PinballToys
    $ 48.00
    $ 99.99
    $ 179.00
