Any ideas if the Ironmonger toy sticking might be from an alignment problem that could be fixed with an adjustment? I hear the motor running, but it initially stuck half way down. I nudged it a little from the top and it went down all the way, but it won't come up now.
This started after I discovered the lockdown bar wasn't latching. The release mechanism apparently isn't aligned perfectly with the notches on the bottom of the lockdown bar, so the yellow handle doesn't return all the way to the right when the lockdown bar is in place. The lockdown bar goes into place, it just doesn't get locked. I tried bumping the lockdown bar downward (not terribly hard) with the palm of my hand to see if it was just slightly not seating perfectly. Didn't fix the lockdown issue, and a little bump to the machine seems to have been too much for Ironmonger. Ugh.
