(Topic ID: 280096)
Illum. string 1 not working after repair
By Brewchap
  • 5 posts
  • 2 Pinsiders participating
  • Latest reply 3 years ago by Brewchap
#1 3 years ago
I just got done removing a hack and re-pinning J115 correctly.
https://pinside.com/pinball/forum/topic/should-i-repair-this-or-leave-it-alone#post-5923054
And I went to test it before I messed with some other pins and connectors that I was going to repair.
My problem is that the Illum. string 1 is not working. It gets it's power from J115 and then sends that power to J121 to a White/Brown and Brown wire, if I understand that correctly. I check J121, and I got power going to the W/B wire. So I guess that should mean that I got a break in the wire going to the playfield somewhere.
Question now is, have I missed anything,and am I working in the right direction.
#2 3 years ago
Quoted from Brewchap:
I'd check AC power leaving the board. Then you'd know board issue ( lost across or through board continuity ) or out in the game like a broken wire from board to bulb sockets.
#3 3 years ago
Yes I have power leaving J120/J121 at 6.8vAC, But I think that I found something on Pinwiki going from pin 8 of J115 to Q18 as shown on this chart. It's not toning out.
#4 3 years ago
On the line that isn't lit ?
Lost your through board continuity on pin 8 did you.
I'd run a jumper from it to the leg on Q18 on the solder side of the board and call it a day.
#5 3 years ago
Yes, pin 8 was the problem. It did not have a path to Q18. I when ahead an pulled the pins connectors and found that the through hole was bad, so I stitched it. That diagram that I found on PinWiki pointed the way to the problem.
$ 14.95
$ 9.95
$ 22.50
bdash's bits
$ 72.95
$ 6.95
$ 37.50
$ 18.95
$ 3.00
$ 7.50
KAHR.US Circuits
$ 5.95
The Pinball Scientist
$ 17.95
$ 329.99
$ 12.50
This page was printed from https://pinside.com/pinball/forum/topic/illum-string-1-not-working-after-repair and we tried optimising it for printing. Some page elements may have been deliberately hidden.
