Hi, I have rebuilt my IJTPA from the ground up successfully, apart from one stubborn issue. The left side flasher and the associated Back Box flasher (Sol 37) both stay on. I did the following to fix the issue:
Re-seated J4 - no dice. The flashers go off if J4 is pulled.
Pulled the 8 Driver PCB and changed the TIP102 Q16.
This did fixed the issue and the flashers worked great... but after a couple of games the flashers came back on steady...
I suspect that the new TIP102 Q16 failed again, but as I do not have a schematic of the board to see the chaine of elements behind the TIP102 transistor, I do not know what could cause it to fail.
The game has no other errors.
If you have a schematic of this board or if you could provide any guidance or suggestions, that would be greatly appreciated.
