I stripped my IJ down and peeled of all the parts, I'm working on rebuilding and I got a LED kit from Cointaker ... the problem is that many things are wrong, and some things just aren't identified at all.
I'm hoping that one of you Williams IJ owners will be able to tell me what you guys are using in the following locations.
Green Left & Right ramp Caps:
The kit suggested a "#44" lamp, but these were setup for either #555/#906 lamps. Can someone clarify what they have in here? Flashers or standard Wedge bulbs?
Mini-Playfield - Red Divider Bulbs
The kit ignores these entirely ... and so doe my IJ documentation. It's also a wedge base for either #555/#906 lamps, but once again I am uncertain which it is and what the voltage for these are intended.
Special & Lites Hand of Fate x2
Under the play-field on both the right and left side are these four inserts. The Red "Specials" are setup to receive the larger #44 lamps, while the white Lites Hand of Fate (or at least that's how it looks to be spelled) use wedge style, either #555 or #906 ... but once again, I cannot tell which and don't know what to stick in there.
Obviously I should have documented these things better, since I have pretty much everything stripped, I cannot just plug things in and try it, and I'd rather get it right as I rebuilt the pin than get it wrong and have to go back to fix it. Any help would be greatly appreciated.
