I don't deny that these problems are often caps and bridges.
I'm very sensitive on the subject, because I've fixed a lot of these that were 'fixed' by other people who didn't know what they were doing, and suddenly, the problem is larger because they have lifted pads, installed a cap backwards, put the wrong part in, etc.
For some reason, hobbyists who won't spend 15 minutes learning how to use a $10 multimeter to check a diode, resistor, or voltage test point will decide they can fix their resetting game by buying a bridge and a couple caps, and diving in head first.
When they have 'fixed' the board, it still resets, or won't even boot far enough to reset, because they managed to tear a few traces while they had the board out of the machine, or worse.
Why people are allergic to a multimeter, but have no problem plugging in a soldering iron, I don't know.
Just like the frequent threads that pop up where someone has a reset problem, and you ask them what they see at a test point, and get no response, or 'it looks good'.
The OP here made the right choice - consulting a professional when he decided it was out of his comfort level.
Clay's guide is a great resource, as is PinWiki, but both of those resources also indicate you should do your homework and try to determine what is bad before shotgunning parts.
I'll help anyone. People are what make the hobby for me, and when I started working on pins, I was a novice, too. Clay's guide and RGP are what kept me in pins - without it, I would've bought one, gotten frustrated, said screw this, and quit. Without Clay's guide and advice I got from people on RGP, I would not be where I am now. I buy project games that don't work, knowing I can fix them, either with knowledge I already have, or guidance from other collectors who have been there, done that!
But if people ask for help, and they can't take a couple voltage readings, I'm not going to 'guess' that it might be replacing a few caps and bridges, because it could be something completely different. I want to *help* people, not hinder them.
I am also glad the IJ is up and running, being enjoyed!
