(Topic ID: 92422)
IJ path of adventure removal?
By kidchrisso
8 years ago
  • 10 posts
  • 7 Pinsiders participating
  • Latest reply 8 years ago by dhalem
#1 8 years ago
Does anyone have pics or guidance on removing the mini playfield? I would like to change out some bulbs, any help would be appreciated.
Thank you!
#2 8 years ago
Take out the metal ramps to the left of and below the POA. Then take out the screw that mounts the front of the POA to the playfield. Then use an allen wrench to loosen the POA from the motor shaft and slide the POA out. Magnetic drivers are handy here...
#4 8 years ago
helps to drink a lot of beer while you deal with that beast.
#5 8 years ago
Getting it to level properly is a real pain. Follow the manual and you will be fine though..
#7 8 years ago
Quoted from JoeJet:
Agree. Good luck getting the playfield to tilt to the right all the way. A little more room would have been great.
#8 8 years ago
Some people move the jackpot sign on the ramp back to make more tilt room, but you also have to notch the lower plastic to do so.
I had a some switch problems with that sucker at one point and took it on and off several times in a day. It isn't really that bad.
#9 8 years ago
Best advice, thanks for leading me in the right direction of the manual. This was so easy to remove. It was more of a bitch to remove all of the old bulbs and install new ones. Peace!
#10 8 years ago
Yeah, changing the bulbs on mine sucked too. I had to remove the board and pull them out with pliers.
YouBentMyWookie
Other
$ 1,419.00
Flipper parts
This page was printed from https://pinside.com/pinball/forum/topic/ij-path-of-adventure-removal and we tried optimising it for printing. Some page elements may have been deliberately hidden.
