(Topic ID: 134629)
IJ idol and PoA opto problem
By diaowee
  • 17 posts
  • 4 Pinsiders participating
  • Latest reply 4 years ago by SOKOL
#1 4 years ago
Hi, the motor optos on the idol head and path of adventure has suddenly stopped working. Other optos work fine. Any ideas whats wrong?
#2 4 years ago
Motors wont work either
#3 4 years ago
Check the AUX driver board, the small one in the upper right corner of the backbox, it is what runs the extra drive transistors for the motors and some of the extra optos.
#4 4 years ago
Check the 12Volt on the small opto board (A17042-3) near the left arm assy.
Connector J1 pin1=black=ground, pin2=gray/yellow=+12V (possible 13-15V)
#5 4 years ago
Hi, I tested the machine with the AUX-board from my TZ, and no difference. I will check the 12v on the small optoboard later today. I can see on more than 1 webshop that TAF also has this small optoboard, but I cannot find it in my TAF. In case I need to test with another board.
#6 4 years ago
Couldnt wait. Checked the 12V and the ground. Both ok.
The complete test report is like this:
Error mini pf, check switches/motor
Error idol lock, check switches/motor
Check switch 94 mini pf
Check switch 95 mini pf
#7 4 years ago
Here is someone else with the same problem, but I dont understand german, and apparently google translate isnt that good either
http://www.flippermarkt.de/community/forum/showthread.php?t=124500
#8 4 years ago
Quoted from diaowee:
Don't find more, in the TAF has no got this opto board, it is only mistake.
#9 4 years ago
The 3 Idol optos and the 2 mini pf optos are on the extra, 9. column in the sw-matrix.
Please check the violet/white wire 4 places (possible tear):
-8 driver extra board connector J5 pin4
-on the mini optoboard J1 pin6
-motor opto sw board and the serial connectors -see the pic-
-there is the sw 94-95 optos below the mini playfield on the backboard -it is hard to find, because need to remove the mini pf.
#10 4 years ago
It is good connection between all these points
#11 4 years ago
Can you try in the IJ another 8 driver board?
#12 4 years ago
I tried the 8-driver board from my TZ. No success.
#13 4 years ago
I have just had this or simular problem. The ribbon wire conection on the CPU was falty. I resoldered the pins of the conector
and all works fine again.
#14 4 years ago
Connecting CPU and 8 Driver Bd.
4 months later
#15 4 years ago
Im almost to embarrassed to tell, but I just found out that the ribbon cable was disconnected from when I resoldered the battery holder
Everything is working fine now, thanks for all the ideas
#16 4 years ago
So now you can enjoy the party. Wish you all a Happy New Year and all the best for 2016
Regards from Hamburg
Peter
#17 4 years ago
You're welcome!
I'm happy the pin working well!
Trabuco Canyon, CA
$ 40.00
$ 123.00
$ 279.95
Pin Stadium Pinball LEDs
Apparel - Unisex
ArcadeMade
PinWoofer
$ 295.00
The Art of Pinball
Arcade Upkeep
$ 259.95
$ 37.50
$ 11.00
$ 149.00
Sparky Pinball
6,100 (Firm)
Zamora, CL
€ 95.00
FlipperLED
7,200 (Firm)
Sale Pending!
Columbia, MD
Collingwood, ON
$ 21.00
KAHR.US Circuits
