[SOLUTION]
I feel like I've seen this issue before, I've just encountered it, and could see it happening again:
After setting up my Williams Liberty Bell (which I have owned for a little while now, but not set up) I found that with all the plugs correctly inserted, I would press the start button and the machine would reset, then step up to ball 1, then go straight to game over before the ball even kicked into the shooter lane.
This is because in transit a wire onto a switch on the hold relay broke off and while it was able to engage itself, it was not able to lock itself on and would quickly disengage. To reattach it, try putting the wire against each switch contact (there is one populated switch and one switch that isn't used/connected), one seems to make the relay pulse which you don't want, and the other locks the relay on which you do want. Turn the machine off, strip a new end to the wire, and solder the wire back to this blade with the other wires.
I also added and reflowed solder to the other end of this wire which of course goes to one of the coil lugs. It looks like at the factory they did not add enough solder to this lug in particular and perhaps it was the same with the other side connected to the switch blade, which is why it fell off so easily.
With the wire reattached and the other solder joint reinforced with a nice amount of solder (even if it may still have worked for the time being), I was back in business and the machine works great once again.
Putting this here in-case anybody has the same issue. Since by now I know quite well how to cover all of my EM bases it was pretty easy for me to find and troubleshoot without a guide (nor a schematic being used) in a couple of minutes by just doing a visual inspection of the layout of the machine, but I know for some it is not that easy, so I hope this helps. This is a very easy <10 minute fix.
I was wrongly also going to add that this would be similarly reproduced if there was an issue with the voltage going to the hold relay, but it's actually NOT, keep in mind here the issue was not voltage getting to the relays switches but rather that (correct and present) voltage not being applied back to the coil by it's own relay to lock it on and was actually turning on (to where it should lock on itself), but then turning off again quickly as it failed to lock on itself. So, this is a very particular and small issue with a big impact but in a very very small range (one small wire, one switch, one lug... sounds like a cover of a song waiting to happen), so if you're having it, chances are this is very likely your problem.
Hope this helps!
Otaku
