(Topic ID: 278595)
Identify this Hack?
By StratDoc
  • 10 posts
  • 6 Pinsiders participating
  • Latest reply 3 years ago by donjagra
#1 3 years ago
I am working on an Amazing Spider Man restoration. Why would someone create this hack connection between the power supply and driver board? Also note, the unattached red/white colored wire. If I disconnect the hack, I cannot tell any difference in starting a game - boots to attract mode, game will start. I do have some switches not registering that I need to track down.
#2 3 years ago
That's a ground mod.
#3 3 years ago
Quoted from donjagra:
Gottlieb system 1 and 80 series didn’t have grounded boards, the only exception being Alien Star. This lack of grounded boards caused electrical shorts in games. It’s a recommenced modification per pinwiki.
#4 3 years ago
Albeit, poorly done.
Exposed wire shouldn't be left swinging in the wind.
That should be spliced and heatshrinked properly, or the whole wire should be redone. I'd probably redo it.
#5 3 years ago
The dude who did it couldn't scramble up ONE lousy foot & a half piece of wire, he had to splice three different scraps together, one of them only an inch long? And then just solder it to a capacitor lead and a top trace right in the middle of the board and no insulation on anything. GeeeEEEzzz!!
#6 3 years ago
Quoted from frenchmarky:
I was thinking he used boards that already had ground mods from different machines and the ground wires were too short for this machine, hence the jumper to connect.
#7 3 years ago
There is also an red/orange wire coming off one the top saucer gi lights That is not connected to anything. Have no idea what that is.
#8 3 years ago
Clay's guide recommend soldering to the cap and the trace in the middle of the board. It doesn't recommend using a bunch of wire scraps.
I cringe a little when I read a for sale add on a system 80 that includes the phrase "ground mods done." This is what they are talking about.
#9 3 years ago
I've only done it once and used the guide, on my BH, but where I was able to I made the connections using lugs at ends of the wires and then bolted them on (two on power board ground plate and one at center of CPU board). Figured if I ever needed to pull a board to repair something, the bolted connections would make it easier. Luckily I have never needed to do that anyway. But I guess would be just as good to solder all the wires but add connectors to the wires so you can unplug them.
#10 3 years ago
Quoted from bluespin:
It's not that the boards weren't grounded, it's that the ground goes through the connectors. Most manufacturer's used a grounding plate and ground thought the screws that hold the board in place. Because the connectors are unreliable in these games, pinball folklore suggests that the best way to improve reliability is to solder a bunch of extra wires to add more paths to ground.
Gottlieb built some amazing games, but they had a tendency to overbuild and created some unique issues that aren't in other games.
4,200 (OBO)
Washington Township, NJ
3,495
This page was printed from https://pinside.com/pinball/forum/topic/identify-this-hack and we tried optimising it for printing. Some page elements may have been deliberately hidden.
