(Topic ID: 114996)
IDC connector pains
By bigdaddy07
9 years ago
  • 10 posts
  • 5 Pinsiders participating
  • Latest reply 9 years ago by TimeWarp1
#1 9 years ago
I've been fighting with a 6 pin connector on my LOTR that goes from the PD board to the CPU board. I had one that was bad and tried to replace it a while back, and had hell to get the wires pushed through the V shaped pass through. I even purchased one of those push tools and that seemed to be more of a pain then help. Anyway, I eventually got it working by just pushing the wires down with a screwdriver, but now after installing a color DMD, I must have bumped them around enough and now I'm back to no power on the playfield again. This time I cannot get the wires through enough to get it powered back up, and the wires are starting to get pretty chewed up from trying. How do you guys get those wires into that connector? What's the trick, because I have to be doing something terribly wrong.
#2 9 years ago
The answer you're going to get from most people is "lose that IDC crap and use real connectors with crimped pins!"
#3 9 years ago
Please tell me what those are? Or better yet, shoot me a link to where I can get them.
#4 9 years ago
You can get them from GPE here:
https://www.greatplainselectronics.com/products.asp?cat=80
Plugs for the contacts may be found here:
https://www.greatplainselectronics.com/products.asp?cat=81
You'll need a crimper as well but conveniently GPE sells those too.
It appears from other threads that the 1026-CT aka BCT-1 crimpers are best for your buck.
#5 9 years ago
OK now were talking. Which should I get for LOTR? Part number 08-50-0134 or part number 08-52-0125? They both are 22 wire size, but look a little different. I would like to get the order right the first time. Thanks!
Also, can these connectors pass through a wire? This particular connector needs to feed two wires though to another connector.
#6 9 years ago
Definitely go with the trifurcon contacts: 08-52-0125 as they make three points of contacts to the pin. Very solid and reliable connection to last longer.
Unfortunately you did spot one downside of crimped connectors but honestly it's that much of a downside if you take your time. Take a look here to get a good idea of how to tackle looped connections with crimped contacts:
http://www.pinrepair.com/connect/#looped
The article recommends soldering but IMO crimping and soldering don't go together. So note this. Since you'll be "doubling up" wire I would grab some of the bigger gauge contacts in addition to the smaller ones: part 08-52-0072 at GPE as that will nicely fit two wires. That way you have contacts to fit 22-26AWG and 18-20AWG and you can use the 18-20AWG contacts for doubled up wires.
#7 9 years ago
Thanks TimeWarp. I will roll with your suggestion.
#8 9 years ago
Make sure and buy a good supply of trifurcon contacts so that you can practice making crimps on some similar sized spare wires first before you do those on your game. A little practice and you will have the technique nailed.
#9 9 years ago
When one of my .100 IDC pins went bad on my CFTBL I bought a variety of crimp pins and a couple tools from Big Daddy Enterprises. He was very helpful with suggestions and got back to me quickly when I had a question. It's good to support our friends in the pinball community.
#10 9 years ago
Almost forget to mention to get key plugs if your plugs are keyed:
Part 15-04-0219 at GPE for the plugs I linked above
$ 99.99
$ 12.00
WilliPinball Mods
€ 7.50
10,400 (Firm)
Juneau, WI
$ 45.95
PinWorlds
$ 8.99
Mitchell Lighting
YouBentMyWookie
$ 259.99
$ 130.00
Dijohn
$ 49.99
Anderson, SC
$ 200.00
Professor Pinball
9,000 (Firm)
Ronkonkoma, NY
$ 29.00
Pinball Photos LLC
$ 130.00
Dijohn
$ 41.00
$ 18.95
PinWorlds
10,000 (OBO)
Deer Park, NY
€ 7.50
Pin-Decals
$ 39.50
This page was printed from https://pinside.com/pinball/forum/topic/idc-connector-pains and we tried optimising it for printing. Some page elements may have been deliberately hidden.
