Hi guys,
I have spent a good 5-6 hours trying to figure this one out. Tried really hard to do this on my own with the schematic but I'm really stuck. I noticed the front rollovers were not registering anything (these register 5 points or 50 when lit by number targets).....then I notice the 5 Point delay Relay is stuck on (which also activates the 5 point relay). I assumed it was one of the 4 front rollover switches. I checked them multiple times and there are no issues with the contacts. I even went through each switch with an ohm meter to make sure it wasn't stuck on. However, if I pull open the "opens rollovers" switch at the ball gate, this relaxes the 5 point delay relay and then the 5 point relay. I'm having a hard time figuring out just what the purpose of that switch is and where it actually ties in too although perhaps it doesn't matter. I don't see it in the schematic. Anyway, if its not the switches, then what else could it be? Closing the "opens rollovers" will quickly register 5 points so it seems the culprit has got to be right in front of me.
Any thoughts on what I should do next would be appreciated. I did duplicate the issue on my Kings & Queens by holding a rollover switch and it acted exactly the same way.
Thanks,
Greg
