Quoted from Mr68:How much? I looked and couldn't find it but I'm not well versed with eBay.
If you are asking about the one these guys were talking about, you can click on their links.
$2500
$2500
Recently bought an Ice Cold Beer and when I moved it the playfield inside slide down. I don't see how to get it back up.. Any help would be appreciated, thanks!
reach up inside the coin door to the right and left and undo the latches and remove the control panel..........then the glass comes off and you can get to the playfield
Thanks Zerbam! Got it working, but I accidentally hit ignore on your post so I can’t see it anymore. Dang how do I undo that..
Also where can I can a replace rubber band for the long pilot system. Someone put duct tape on it..
These are what should be holding the playfield in place, right below the motors.
And a picture of the belts. You will only need two of them. I have had good luck with them.
0050A860-3DE9-4452-9804-1ECF8F7346B1 (resized).jpegF699BC37-1DCA-42EC-8713-5C841125A646 (resized).jpeg
20B00790-0F3C-4C58-99F6-EDEEB428C34B (resized).jpegQuoted from thepinballworks:These are what should be holding the playfield in place, right below the motors.
Thanks! I figured that out eventually, the motors seem a little loud and squeaky any solution for that?
I have put a couple of drops of 3 in 1 oil on the gears, but it might still be the motors that are getting loud with age. It could also be the side rails that need to be cleaned and they are cousing extra stress on the motors.
Quoted from GPS:Looking for an ICB. Please let me know if you have one avail
Thank you
I have a Zeke's peak, but I'm over here in NJ
Quoted from Skyemont:Anyone have a ICB for sale. I have not seen to many posted lately.
The one I built sold locally. I never posted a for sale ad.
Would there be interest in a reprint of the scoring panel (yellow) and (white zeal’s)? I still have my print files.
Quoted from flashinstinct:Would there be interest in a reprint of the scoring panel (yellow) and (white zeal’s)? I still have my print files.
I could use one or two of each of them.
Quoted from thepinballworks:I could use one or two of each of them.
Same here please.
So I just picked one up today that has been sitting in storage for some time.
I power it on and all I get is marquee light and speaker static. No display
Check fuses and reset all the connectors. After that start checking the voltages off the power supply in the bottom. They are in the manual that is online. If all are correct then something on the main board may be the problem. That is where I would start.
Fuses tested ok.
I cleaned the jamma like board pins as they were pretty dirty. I reseated all the socketed chips.
Powered on the machine and I now get playfield lights as well as the marquee, tilt, star, and game over lights, but nothing else.
When I power it off, I hear the motor for a split second.
I’m going to send these off for repair
Thank you
Still looking!!
Thank you
I would be in for an ICB replacement!
Arcade shop used to have the entire panel (are you offering the whole panel or just a decal?).
I had purchased one, then they went out of stock. People have been trying to buy them ever since.
Should be an easy sell to most owners, even ones where it's not worn.
Count me in as well!
Quoted from Cmjb13:Fuses tested ok.
Go to arcadeshop.com
Get the ice cold beer power supply with the little pcb, thank me later
Quoted from thepinballworks:Arcade shop is out of stock of the power supply.
That I can see
You can give them a call and they can usually at least tell you when another may be available
How loud is everyone's Ice Beer game when you move the joysticks up/down? I have nothing to gage the noise too since I've only had one in my collection.
Does anyone have links to the coil plunger, coil, and sleeve?
I am running into an issue where the game does not kick the ball back up into the main playfield. I get no solenoid fire. I cannot remember which transistor it is that drives that solenoid, but this has never worked in my posession.
Any help would be appreciated!
Quoted from Gundam_Pilot_:Does anyone have links to the coil plunger, coil, and sleeve?
Did you see this post, as this is what fixed mine;
https://pinside.com/pinball/forum/topic/ice-cold-beer-icb-owners-thread/page/5#post-5297050
I have a near CQ Gottlieb Gladiators pinball that I may consider trading for an ICB or Zekes+cash from me?
I value the game around $3500 and would like to find an ICB around $3200+/- -just putting out feelers if anyone may be interested in a trade
Owners of ICB/Zeke's Peak. Please see this product listing.
Thank you
https://pinside.com/pinball/market/classifieds/ad/146068
thumbnail_IMG_0222 (resized).jpgthumbnail_IMG_0223 (resized).jpgthumbnail_IMG_0224 (resized).jpgQuoted from flashinstinct:Yeah I had made silkscreen printed direct on plastic. So these would be the same.
I am in for 3 !
So now there is a complete board set available for ICB-when will we see the remakes start popping up? I am interested in a new minty ICB remake-any news?
Quoted from pinmister:So now there is a complete board set available for ICB-when will we see the remakes start popping up? I am interested in a new minty ICB remake-any news?
Got this from the owner this weekend (after IAAPA):
“Thanks for your interest. The Ice Cold Beer and Zekes Peak coin operated arcade machines will be in full production in January 2023. The MSRP on the games is $5499.00. These games will be available through most of the US game distributors. We just launched our new website that will have continued updates on the games including who is distributing them, when they are in stock and where you can play them in the bar and arcade settings. The first few production machines are currently at the IAAPA show in Orlando. These were made on the production line and we are currently in the process of making adjustments and very small modifications to the production process to make the games work perfectly. We will do one more small production run in about 3 weeks to make sure everything from looks to performance is exactly to specifications. This should put us in full production in early January. Each machine will come with it's own, metal plated stamped serial number so you will know what number your machine was in the early production process. I will also add your contact info to our email list that will update progress on a routine basis. Please feel free to reach out with any additional questions.
Please check out our new website that contains all Ice Cold Beer and Zekes Peak related information at www.retroarcaderemake.com
Sincerely,
Tom Cogan
Member owner Retro Arcade”
Quoted from evh347:Got this from the owner this weekend (after IAAPA):
Sincerely,
Tom Cogan
This is excellent news. Email enquiry sent via your website.
Quoted from Flipper_Ripper:Does this game record high scores where you can type your initials?
No
After sitting on this for two months and trying a bunch of trades, I'd take 3400 cash for Zeke's peak with extra mpu board and new belt set. North Jersey.
Quoted from yzfguy:After sitting on this for two months and trying a bunch of trades, I'd take 3400 cash for Zeke's peak with extra mpu board and new belt set. North Jersey.
Wish it was closer to me.
Quoted from thepinballworks:Wish it was closer to me.
Me too! I don't wanna sell it, but I'd like to send my kids on an expensive class trip this summer, so I could use the cash now.
Need some help and I've given up on scanning through the thread. If this has been brought up, please point me in the right direction.
Game ran fine for two years and someone put in a different power supply kit before i got the game. But now when I turn it on the game is stuck and wont finish its boot. I get no sounds, but can hear the speaker hum. I have all the lights flashing on the playfield as if it's like a pinball and you're doing a lamp test. The displays read zero on each one. The test button on cpu does nothing.
I've tested the voltages on TP 8 and 9 of the cpu. I've adjusted the power supply and now have 6 and 12 volts on those test points. Originally had only 10 on test point 9.
Any help would be appreciated.
Quoted from rottenrobert1313:Need some help and I've given up on scanning through the thread. If this has been brought up, please point me in the right direction.
Sounds like maybe a short of the test button (maybe a pinched wire somewhere??), or an issue with an ic on the board
Quoted from Chosen_S:Sounds like maybe a short of the test button (maybe a pinched wire somewhere??), or an issue with an ic on the board
Could be the test button as when I was pressing it in a few times I thought I seen the lights stop flashing briefly. When using the test button...dose it have a function like a pinball machine and flash all the lamps on and off?
Anyone know where I could source a replacement for the pin attached to the motor that sits in the plastic wheel to make it turn?
This page was printed from https://pinside.com/pinball/forum/topic/ice-cold-beer-icb-owners-thread/page/15 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
