For an intro to electronics and a good basic reference book, I can highly recommend "Getting Started in Electronics" by Forrest M. Mims III. It covers the fundamentals of electricity and the common components that you would typically encounter (resistors, diodes, capacitors, transformers, switches, integrated circuits, etc)
http://www.amazon.com/Getting-Started-Electronics-Forrest-Mims/dp/0945053282
Quoted from amkoepfer:Is ba10339 the number i need? Looks like marco has them
It's a variant of the LM339. If you search for that, it should yield a lot more results.
Quoted from ForceFlow:It's a variant of the LM339. If you search for that, it shoud yeild a lot more results.
Cool thank you. Marco has the one with the same numbers, so i guess ill judt order that with other parts i need
Before you rush out and buy chips - you say you don't know anything about them, I assume then that you also don't know how to tell if a chip in faulty OR worse, how to replace the chip without destroying the printed circuit board.
How about ask a few more questions here and take some additional advice on board before changing a chip that might not resolve your problem BUT has every chance of making things worse!
What exactly causes you to think the LM339 is faulty? What does the machine do or not do that leads you to this conclusion?
I say this because generally, LM339's and their variants such as yours are pretty reliable.
Quoted from pins4u:Before you rush out and buy chips - you say you don't know anything about them, I assume then that you also don't know how to tell if a chip in faulty OR worse, how to replace the chip without destroying the printed circuit board.
Ya, still troubleshooting before i replace the chip, but luckily i am good at soldering on boards if i do need to do it
If the LM339 is bad, it is probably because somewhere coil voltage has hit the switch matrix. Use a socket for the new chip in case there is a fault on playfield and you need to replace the chip again.
Still troubleshooting cowlynn. Junkyard flippers are dead, left eos stuck closed taking out left eos, left flipper, right eos, right flipper, and spinner. Eos is good
The flipper and EOS switches connect to Fliptronic board so check that first. Spinner might be a separate problem.
EDIT: Sorry, this is WPC95 so no Fliptronic board...
Quoted from ForceFlow:For an intro to electronics and a good basic reference book, I can highly recommend "Getting Started in Electronics" by Forrest M. Mims III. It covers the fundamentals of electricity and the common components that you would typically encounter (resistors, diodes, capacitors, transformers, switches, integrated circuits, etc)
amazon.com link »
The moment I saw this book was by Forrest J. Mims I knew I had to order it. I have several of his old electronics project books from Radio Shack and need to add this to my collection.
Quoted from girloveswaffles:The moment I saw this book was by Forrest J. Mims I knew I had to order it. I have several of his old electronics project books from Radio Shack and need to add this to my collection.
I subscribed Popular Electronics magazine 1977-1982 and the first article I used to read was the Experimenters Corner, and later Project of the Month by Forrest Mims.
This page was printed from https://pinside.com/pinball/forum/topic/ic-chip-compatability and we tried optimising it for printing. Some page elements may have been deliberately hidden.
