(Topic ID: 236577)
I500 Indianapolis 500 turbo issue
By newtoit
5 years ago
  • 9 posts
  • 4 Pinsiders participating
  • Latest reply 5 years ago by Schwaggs
#1 5 years ago
Im having trouble with my turbo. It comes up as an error for turbo sensor and index sensor. The turbo spins. In switch test the 2 switches register.
In game the ball goes into it it takes about 5 seconds then spins it out. When lock is lit it does not hold the ball, it spins it out but still counts it as a lock.
In the turbo test both sensors fail.
I took the ramp out and took the turbo board out. Cleaned both optos, reflowed solder on the small turbo board.
#2 5 years ago
I had a similar problem some time ago. The inconsistency was driving me nuts. Upon studying the manual I realized that the set screw was missing a washer. Once installed, I have not had a problem since.
#3 5 years ago
After looking at the manual. Mine does not have a nit on the top that holds the impeller down. Mine has a screw that goes into the shaft.
I circled it in blue in the pic.
Screenshot_20190219-130633_Drive (resized).jpgScreenshot_20190219-130633_Drive (resized).jpg
#4 5 years ago
Footage of it in turbo test.
#5 5 years ago
It looks like it is struggling when it is going slow. So i manually helped it spin by hand and go figure it passed both tests.
Does this mean the motor is bad? The motor looks like a sealed unit, is it serviceable?
#6 5 years ago
The motor appears to be spinning fine prior to slowing. I know you need to have a washer under the spinner or all sorts of problems happen. Something is going on where the opto's aren't being interrupted. However, it is strange the work when manually interrupted by hand spinning.
#7 5 years ago
I stumbled across this post while researching the motor ( 14-8021.1 )
Screenshot_20190219-200448_Chrome (resized).jpgScreenshot_20190219-200448_Chrome (resized).jpg
#8 5 years ago
Opened up the turbo gearbox and cleaned the old grease out. Added new grease. Also sprayed some brake cleaner into the motor by the brushes and spun it around.
Put it back together. Slapped it in the game. It i'l mmediatwly passed the turbk test. It doesnt make a grinding noise. It is operating flawlessly for the couple games i played.
#9 5 years ago
Quoted from newtoit:
Thanks for sharing your fix!
$ 18.95
$ 54.96
$ 17.50
Hardware
$ 5.00
$ 22.50
bdash's bits
$ 285.99
PinSound
$ 12.00
arcade-cabinets.com
Nezzy's Pinball Prints
Charlotte, NC
KAHR.US Circuits
€ 17.50
$ 22.50
Magazines/books
Pinball Magazine
Filament Printing
$ 9.99
$ 329.99
This page was printed from https://pinside.com/pinball/forum/topic/i500-indianapolis-500-turbo-issue and we tried optimising it for printing. Some page elements may have been deliberately hidden.
