(Topic ID: 91324)
I REALLY need system 80 experts help , haunted house
By PlatinumPinMike
9 years ago
  • 18 posts
  • 8 Pinsiders participating
  • Latest reply 9 years ago by G-P-E
#1 9 years ago
Really need some help , just pick up a Haunted House , my first system 80 pin.
It have the Pascal Janin board , all the fuse are good , all the GI are lighting up but game does not boot and there is no display , if i let the game on for a little while i can hear the attract sound but that s it.
Should i start with re pinning the connector or looking for something else ...
Mike
#2 9 years ago
Start with checking the voltages on all boards to see if they are correct.
#3 9 years ago
... which I'm going to guess is going to lead you to the power supply.
#4 9 years ago
Well my machine is equiped with only sound board and Pascal Janin 4 in 1 board , the connector are all original except one , you think I should start with this ?
#5 9 years ago
You still need to check voltages to make sure power is getting to the board from the transformers. Connectors are something that could possibly be causing issues.
#6 9 years ago
Where do i check the voltage going to the board ??
I dont know from which connector is coming the power , but i see power leds ground and 12 V are lighted when i power on the machine.
Mike
#7 9 years ago
Start with the power supply, check the test points on that board, then move on to the other boards. They should all have test points on them. Refer to the manual for proper voltages at each TP.
#8 9 years ago
Wow, I'm sorry! Comprehension problems today. The others are right, check that the board is getting the proper supply from the transformer.
Haunted house has two, I'm speaking of the larger.
#9 9 years ago
Here is a few pics of the backbox , boards and where i think test point are , ill report back when tested
IMG_2139.JPGIMG_2139.JPG IMG_2140.JPGIMG_2140.JPG IMG_2143.JPGIMG_2143.JPG IMG_2145.JPGIMG_2145.JPG
#10 9 years ago
A2J1 is looking a little funky. Board has test point for ground and bvoltages right in the section with LEDs.
#11 9 years ago
Quoted from bingopodcast:
Is that what plug it is? I'm not drunk enough to see that last pic.
#12 9 years ago
Seems to me I've seen in other threads that Pascal will help you if you contact him. Don't know if there is any truth to that but could be worth a try.
#13 9 years ago
Quoted from PlatinumPinMike:
Mike
Did the Pin work when you picked it up? If it did, I'd recheck all your connections and connectors to make sure they are going to the correct location, they are installed correctly and the wires are inserted into the connector contacts securely. Might also be a good idea to use a magnifying glass and sheck all the contacts for corrosion, damage, etc.
Since you have a Pascal replacement all in one PCB, I tend to think that the Pascal PCB is OK. Pascal's PCBs are rock solid and he has designed a lot of safety features into his PCBs to avoid having coils lock on, etc.
if it didn't work, well, we're all here to help out.
#14 9 years ago
pdman , the pin was not working when picked up , the previous owner had it for 1 year and it always worked ok but when he moved it to a shop it stopped working , all connectors have been double checked , just made some voltage test on the board , most are ok except the TP for 8V , give me 0.16 v
#15 9 years ago
RWH , i contacted Pascal , waiting for a response !!
#16 9 years ago
Good move contacting Pascal. Great guy. If there is a problem on his PCB , He will definitely. know what's wrong. good luck
10 months later
#17 9 years ago
connectors connectors connectors. I see they are original. You can replace these with standard .156 pins. that may eliminate a lot of your issues.
#18 9 years ago
Quoted from bumgahdna:
^^^ What he said.
Combined with what was previously posted -- plug at A2J1 looks pretty gnarly and would probably be the easiest of all of them to replace. Probably good idea to repin or replace them all ... but that black double sided bugger can be the tough one to repin (pins are NLA).
3,950 (OBO)
Centerport, NY
Toast-Mach1 Mods Shop
2,950 (OBO)
Shakopee, MN
$ 1.49
Daddio's 3D Printed Mods
$ 1,159.00
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/i-really-need-system-80-experts-help-haunted-house and we tried optimising it for printing. Some page elements may have been deliberately hidden.
