Quoted from snyper2099:one-off custom pins come to mind
In my custom machine I use multiple smaller driver boards, with some mounted under the playfield. There are several advantages, setting aside cost savings by having a lot less wire, I think one of the big ones is troubleshooting and repair. In my case each board has two banks of eight solenoids (one board is configured as a lamp matrix, so that is al little different) If a failure occurs to a driver board it is quicker to identify the cause, since it likely only 8 or 16 of the solenoids that would be impacted, not the whole machine. It is much easier to then swap a board to do quick trouble shooting. Doing something stupid (e.g. dropping a screw driver with high power on), would likely damage only one board or half of one board vs an entire driver board controlling all powered items. The cost of replacing a board is significantly less (< $100) which can let you get back up and running quickly before dealing with repairing a board.
One downside to mounting the boards under the playfield is the increased risk of the board being damaged by something coming lose under the game or from the increased vibrations, etc. from game play. Boards in the backbox are far more protected in that sense. My game has only seen several hundred plays, so too early to assess the risk of being under the playfield. However, there are plenty of games with boards mounted under the game (opto boards, motor boards, eddy boards, etc.), and I am not really aware of that being a big issue relative to damage and failures.
While ultimately it is the same amount of heat, the smaller boards are spreading that, so while the total is the same, with it not being so concentrated, I would expect that heat inducing failures would be reduced. Having said that, we have already seen over time efforts done to reduce this (e.g. bridge rectifiers being replaced by discreet diodes).
Only time will tell if this design is more reliable.
