Quoted from kvan99:The new boards have less components so they produce less heat, this fact alone makes them much more reliable. Remember the home appliances from 20 years ago? The TVs,VCRs and PCs, remember how often they used to break? The old stuff was easier to repair but not more reliable. The diagnostics will be the same, switch rows and columns sort of like WOZ.
I don't think you understand the advantage/disadvantage dynamic. The components are simply "spread out" in a modular design. There are less components on "the main board" or "driver board" or "head of the machine". They are instead, placed in the cabinet or under the playfield. This system has distinct advantages AND disadvantages over what companies like Stern produce.
This "advantage" you point out is not necessarily true. The heat is simply spread out better, not reduced or eliminated. The heat in the head is certainly changed/moved. However, it is only reduced if the power/transistors/coils/boards are more efficiently designed. Again, if they are better, that's great. I would like to also know the disadvantages. With new design, always comes new cost/diagnostics/reliability concerns.
Correct me if I'm wrong but is there is no such thing as a pinball machine that never breaks or requires service? I've never seen one in my life.
Unfortunately, a "NEW WAY" Solid State concept regarding the engineering of the pinball transistor/coils that "makes the magic happen" has not come to light in my lifetime. Sure, things have gotten better and more efficient (even with Stern) but you still have to have a cost effective way to mass produce a system to get those balls and coils do what you want them to do. I've seen technologies like pin2000 tried and fail. I am encouraged by JJ using a conceptually similar approach and, it seems to work very well for what they were trying to accomplish.
I am really curious to see if a modular design is successful. It is something I have ALWAYS thought about for years but have never really seen put in to practice until the last few years in pinball. (one-off custom pins come to mind)
Unless I'm missing something obvious here, please correct me.
