Last month I discovered that the 1st Ball relay on my Royal Flush ('76) was burnt, so I replaced it. The machine played after that, but it continued to be a PITA. So I pulled up the bottom panel and discovered that three other relays were burnt: Tilt Hold, Game Over, and Hold. While waiting for my package from PR, I examined all the relays in the banks and gave them a wipe with a flexstone. Last night I replaced the relays and hoped that I might have fixed some of my problems. Nope, it only added fuel to the fire.
Now when I press the start button the machine resets fine, but it won't kick out the ball (first time this has happened). The ball just sits in the out hole and the motor endless turns as the O relay (Ball Return) clicks on and off. If I manually kick out the ball, the motor stops turning, the game begins and scores.
When I drain the ball, it's the same result as before (motor runs endlessly). Manually kicking out a ball moves the machine to ball 2 and the motor stops again. And then at the end of ball 3 the machine switches to game over when the ball drains, so I think that out hole switch is okay.
I'm assuming that the problem lies with the O relay not locking on, but I don't know what to do about it.
I have the schematic, but I struggle reading it.
Thanks in advance for any help/ advice!
