(Topic ID: 239959)
I installed all these capacitors on Evel Knievel switches and ....
By AdjustFailure
3 months ago
  • 20 posts
  • 11 Pinsiders participating
  • Latest reply 3 months ago by pacmanretro
  • Topic is favorited by 9 Pinsiders
#1 3 months ago
After doing some reading on these forums, I replaced missing, absent or snipped capacitors (.047uf / 100V / 10%) across all these switches
on my Evel Knievel:
- both sides slingshot switches
- three right side stand up targets switches
- center stand up target switch
- all three pop bumpers switches
I had read differing opinions whether these capacitors are required or desirable but I thought I would try and see the difference.
As a result, the game seems to be more responsive and faster in general. Now I am wondering is this just my imagination or why
doesn't everyone do this cheap quick mod to make their game faster and more responsive?
Secondly, am I doing any potential harm to the components in the long run if I use capacitors where they are not needed? I am not getting
any "phantom" switch triggering or other problems.
#2 3 months ago
Just my guess, but I don’t think adding the capacitors will make the game faster.
I agree with adding a capacitor to the center target- I think sometimes I hit it so hard that the switch closes and opens too fast so I don’t always get the credit for it.
I don’t think you’re going to hurt anything with the extra capacitors, but let’s hear from others.
#3 3 months ago
On Bally games, they are required for any fast-react solenoids (that's slings and pops) to ensure that you get the score for the fast react solenoid. (Without them, sometimes you will only get the solenoid reaction and not the score as they are 2 different routines in the code). The slings and pops could seem to react faster with the caps because it would always activate on the first 2 reads of the switch instead of possibly the second and third (which is a normal switch response).
They should also be on any standups where there is a possibility of a very fast hit, like the standups, or sometimes rollovers. Those switches are not read by the fast react routine so there's no 'faster' reaction time; in this case, the switch pulse is longer, lengthening short switch hits slightly to ensure they aren't missed.
It won't hurt anything but be aware that sometimes stray EMF from holding a flipper up can be picked up by poorly made caps causing a phantom firing of the sling or pop when you let the flipper down. You won't get the score from the pop/sling but it can fire seemingly randomly.
#4 3 months ago
I did this on my SBM and it made a big
difference. Well worth the time to do it.
#5 3 months ago
As Solchar says, they are needed on fast hit targets. Not so much required for slow hit switches like drop targets and saucers. Believe me, if an engineer lost money because a target didn't register during an in-house tournament, there would be extra capacitors on the switch the next day!
#6 3 months ago
Very good, thanks.
#7 3 months ago
Quoted from lowbeau67:
Yes, SBM really needs them as it's so fast and the standups will not always score on fast hits without the caps.
Slings too, but especially that center N target in front of the horseshoe. Mine seemed to score about 40 percent of the time before I put a cap there.
Tom
#8 3 months ago
I have a stack of replacement caps for older Ballys. If a stand up switch doesn't register replacing the cap makes it much more responsive.
#9 3 months ago
Anybody have a part # and link to these. I noticed snipped ones on mine, but had no luck with the part# on them. Thanks for any help and thanks for this thread.
#10 3 months ago
Quoted from Buzz:
I got polyester film (although I understand ceramic disc work too) capacitors .047uf / 100V / 10% from ARROWNAC.COM. They seem to be a good source, and free overnight shipping. I got this p/n QYX2A473KTP on the Arrow site. Or generically you can use a 473J capacitor.
I replaced/installed on all the switches for stand up targets, sling shots and pop bumper capacitors. These are not polarized.
Note that these are spec'd for Bally early SS games like Evel Knievel, the Williams etc are different spec capacitors.
#11 3 months ago
Are caps any use on other brands, like Gottlieb?
#12 3 months ago
Thank you. My early Ballys have some of them clipped and going by the numbers on them I wasn't having any luck or knew why they were there or why they were cut. Knowledge is power and thanks for the thread.
#13 3 months ago
Quoted from Topher5000:
I just looked at my EM Gottlieb game El Dorado, there are no capacitors on any playfield switches.
But I would assume later SS Gottlieb games would use them.
But makes me wonder, would putting some .047uf caps on the El Dorado sling shots, pop bumpers and stand up & roll over switch might make them more
responsive? Anyone tried that on EM game and/or know if may cause other unintended problems ?
#14 3 months ago
They are out of stock but can't wait till there back
#15 3 months ago
Quoted from Buzz:
I have done this on my games until i get a chance to replace the caps.
They have been clipped, because they are probably faulty and shorted. If they were left in place , they would have caused continuous scoring. Just replace them and you should be good to go!
#16 3 months ago
Quoted from Buzz:
Wouldn't these ceramic ones from Ed work?
https://www.greatplainselectronics.com/proddetail.asp?prod=CCD-0.047uF-100V
#17 3 months ago
Yes - for Bally. Somewhere along the line, I got a bag of 1000 at an estate sale. They are pretty cheap, and with that many, I install new caps on all the Bally machines I work on. Based on what I have been reading, I've been adding caps to switches that I think need them, just like the OP.
#18 3 months ago
When I saw the % I wasn't sure. If those would work I would definitely get some. I order from him for all my molex stuff, TIP's and diodes. Always been treated great.
#19 3 months ago
I didn't see the part about Bally switches when on his website the other day or when I typed my response. Man I must need to just give in to getting some glasses. Thank you just placed an order for 100.
#20 3 months ago
Quoted from Buzz:
Yeah, I thought that tolerance seemed weird too! But Ed knows his stuff and hasn't let me down, so I figured they would be fine according to his description. I've honestly never heard of a tolerance like that. Typo?
I'm sure they are fine to use; can always double check with G-P-E too
€ 3.95
Multigame
2,500 (OBO)
Aurora, CO
$ 149.00
3,100 (OBO)
Sioux City, IA
$ 7.65
Cabinet Parts
Third Coast Pinball
$ 279.95
$ 86.95
Third Coast Pinball
$ 21.00
$ 399.95
