All the GI going out at the same time suggests the 6V circuit (i.e., the GI circuit) fuse blew.
If the fuses are labeled you should be able to easily find which one might be the problem. If it's blown, replace with correct one (as per label near fuse holder or schematic--don't assume that the previous fuse that was installed is correct).
The fuse might have blown because it's old and it may not blow again anytime soon. But if it does continue to occasionally blow, the problem could be a short. For example, a woodrail of mine kept blowing its 6V fuse but only during certain games. I finally discovered that it was blowing as soon I gained more than 4.99 million points. The problem turned out to be a shorted out socket for the 5 million lite.
Good luck!
