I am desperate. My Hyperball game cannon will not work. It keeps blowing the fuse F2 on the power switching board. I have read some other posts that seem to have a similar issue but they never seem to share the resolution to the problem.
I have tested the bridge rectifier (BR1)
I have tested the varasitor (VR2)
I have tested the diode (D1)
I have tested the capacitor (C3)
These are all the suggestions from the manual if the F2 fuse blows immediately as mine does and they all test fine. There is one suggestion from the manual that I have not tested (6C2) (manual suggestion pictured) but I am unsure where that is as it is not on the power switching board like the other components I listed.
The cannon coil ohms out at 11 ohms as it is supposed to per pinwiki.
Everything else seems to work on the game. Even the cannon sounds are present when the triggers are pulled but does not fire. The boards were serviced by an experience fella.
If you have any input into this issue I will appreciate any suggestions.
Thank you!
