So I was fixing the an issue with the wiring to my drop target opto board and when I got that fixed and put the pf down to do a test game I discovered that the Ferris Wheel no longer turns.. The opto works that registers the left cheek light, however the motor won't turn. I tested the 50V circuit that runs the motor and I am only getting 38 volts, is this normal?
Anyone have any advice here?
Thanks.
