Here are some direcitons. Hope they help.
Taking the bracket out is pretty straight forward. You have to take his arms off there is a screw in each that is not to bad, you will need a short screw driver and will have to turn him as there isn't much room. Then you will have to remove the two screws in the base of the Hulk body, these are a real pain as there is no room at all. Best to have an offset screw driver. They also have lock tight on them so they are kind of hard to get started. There are also two screws that go through the back of the assembly into his chest. These I didn’t even know about until I had his body off as there is no way to see them or get at them whit the thing in the machine, they just pulled out as I lifted his body off the bracket. I know of no way to get them back in either because I can’t see how you can get the bracket through the hole with his body on, and once it’s in the machine you can’t get to them. Someone else may have a way but I couldn’t figure it out. I just left them out and it seems to work fine, the two screws at his base do a good job of holding the body on the bracket and I have not noticed him wobbling at all.
Once you get his body off then you can stand the playfield up and just take the screws and a couple of nuts out of the assembly on the bottom. Once you get the screws and nuts off you will have to turn the bracket about a ¼ turn so the posts his arms attach to are lined up with the biggest part of the hole. Then you just tilt it and get one of the posts through the hole and then it should just slide out. Be careful as the posts tend to get hung up on the plastic that is behind the Hulk but if you get the posts below the plastic before you get it turned completely you should be good you also have to watch all of the wires on the bottom of the playfield as they tend to grab hold of the bracket as you are turning it.
There are three connections you have to take off to get the bracket out. There is an IDC connection going to the board on the bracket, one connection going to the two coils you can see and one going to the coil in his back.
Once out you have access to the coil. The coil is held on with a couple of screws at the top of the assembly and comes apart real easy once you get it out, it is easier to solder the wires back on with the coil out of the bracket.
Putting it back together is just the reverse and like I said the only issue I had was the two screws going from the back of the bracket into his chest. Not sure how to get them back in with the playfield in the machine, could probably do it with the whole thing out but I never had an issue with his body flopping around even with the screws left out.
Hope this helps I am not the best at writing directions, just let me know if you have any questions.
Mike
