I have an early version of HSII: Getaway in which the coil that kicks the ball up the shooter lane is a 23-850. In the later (and more common) version of the game, Williams changed this coil to the A-15708 for more power; however, this change also necessitated refitting the machine to accommodate the larger sized coil - the A-15708 is simply too large to be fitted into my (earlier) version of the game.
My problem is that the 23-850 doesn't have enough punch to propel the ball around the loop at the top like it's supposed to. Following the consensus that less wrapping around the core of the coil leads to a stronger coil, I've also tried a 23-800 and a 23-750, each of which were progressively weaker at getting the ball to the top of the playfield.
Is there anyone out there with the earlier version of Getaway who has solved this problem, and if so, how?
--BB
