Hey guys,
So, recently I installed a new coil sleeve and re-aligned my shooter lane solenoid. Unfortunately upon bootup, something got crazy and the shooter lane solenoid no longer works. It did work once, and then I strongly believe that both the solenoid's lugs were on the leaf switches of the right flipper, and I caused something to short out . I get 0 volts at both lugs of the solenoid on my DMM with one lead on one lug and the other on ground. All of my other solenoids are getting power, so I know it is isolated to just my shooter lane solenoid.
So, on HS2, there is a high current driver board on the top left of the PF (this is with the PF propped up against the backbox) with two IDC connectors. One connector goes to the shooter lane solenoid; the other goes to the rest of the wiring harness to the machine.
After a solid night and morning of diagnosis and many tests, I found that I have continuity from the brown/yellow wire of the IDC connector on the high current driver board to the other end which is at J127. For the other wire - the purple/orange stripe wire, the manual shows it going back to J107. I traced the wiring through the machine, and this wire goes straight from the IDC connector on the high current board to the J107 connector - at least that is what the manual shows. So I ran a continuity test there - nothing. Then I noticed J109 had the exact same kind of wire, so for kicks, I did a continuity test there - and the audible chirp went off - indicating continuity - even though the manual shows it should go to J107.
So, here's the question - can someone with a HS2 verify my results? I know that every once in a while the manuals are wrong, but this is something that could mean possibly a fried board, so I'm just asking for someone to verify my results.
Later today, I am swapping BSD and HS2's cpu boards to see if the problem follows BSD. If it does, I know it is in the cpu board. If not, I am thinking the driver board may have something wrong with it.
Needless to say, until I fix this, my FS thread for HS2 is on hold/suspended.
Help.
