My opto 81 and 85 are not working. I soldered on new optos on both and it didn't change anything. They were working few weeks ago. Where should I look to fix this problem? any help will be greatly appreciated. thank you
For reference, opto 81 is the 1st of the 3 optos magnets and opto 85 is the made loop opto for the sc ramp.
I've checked the wire harness for continuity and they all check out fine. So I did the mpu testing following the instructions on pinwiki by testing j206 and J208 with jumpers and they all register on the switch edge test.
So is my next course of action running test on accelerator board and opto board? Or are there any other tests I should perform before running tests on opto and accelerator board? Can someone explain me the steps to do this? I couldn't find it on pinwiki as the opto board test they show is different.
Please bare with me as I'm still learning all this electrical and pinball repairing. Thanks and any help will be greatly appreciated
Quoted from V4Vendetta:Are the leds on the accelerator board supposed to be lit when working correctly?
The LEDs are usually off when they are lit.
This page was printed from https://pinside.com/pinball/forum/topic/hs2-supercharger-opto-issues and we tried optimising it for printing. Some page elements may have been deliberately hidden.
