High Speed 2 Getaway, needs a DMD board repair, and one transistor on the power driver board repaired, the ball launch transistor. - 2000 as is 2200 repaired
Johnny Mnemonic minimal cabinet fade, on the very bottom of side of cabinet has some nicks, drop target needs minor repair and hand magnet needs repair, also flipper transistors need replacing - 1900 as is 2100 repaired
Congo green artwork on side, not white version, needs audio video board repair, dot matrix is scrambled because of the board error, also could use he GI connector repaired as it has the common burn on it. - $2500 as is, nice example, needs shop job
No fear - 2200
Flash - 800
Gottlieb strikes and spares - 1500
Firepower needing cpu repair, every coil in machine is new - 750
