(Topic ID: 114510)
HS2: Getaway
By Kholmes
5 years ago
  • 68 posts
  • 15 Pinsiders participating
  • Latest reply 5 years ago by Kholmes
There have been 28 images uploaded to this topic. (View topic image gallery).
There are 68 posts in this topic. You are on page 2 of 2.
#51 5 years ago
U20 appears to be bad. The wires are green orange and all of them are out. Matrix switch 31-38 not working going to J206-3 on the u20. This is on the cpu board. Help???
#52 5 years ago
J206 pin 3 only pulling 8 volts. Is that correct? The other pins are pulling 12 volts.
#53 5 years ago
Quoted from Kholmes:
Yes. The U20 chip is on the MPU just below the battery holder. The manual will show you exactly where it is. I can't say, for sure, that this is your issue. All I can say is this chip can be damaged when something on the switch matrix is shorted out.
Williams saw this and started socketing this chip soon after Getaway. Your's is probably soldered directly to the board and, if removed, should be done with a proper desoldering tool like the Hakko 808. This is to help avoid damaging the plated through holes. Then, install a socket and a new chip. I can't remember what chip it is but the manual will tell you. Also, if you don't have a temperature controlled soldering iron, you should not be doing board work.
Note, if you've never done soldering work to a board before, I highly recommend you practice first. Replacing chips are not an easy thing to do.
You can also buy replacement MPU boards to avoid having to do this.
#54 5 years ago
Thanks for the help. I believe your right. I hope the cpu isn't expensive. Thank you so much. I think you're talking about the CPU board.
#55 5 years ago
Williams called the CPU board, MPU. So he's talking about the same thing.
#56 5 years ago
No prob. We determined it was the board. Nothing else it could be. We did 5 hrs of troubleshooting. I ordered through K'sArcades, rottendog. Should bring it back to life.
#57 5 years ago
I used a rottendog board in my hs2. It worked well for me hopefully it will fix yours as well. It's a fun game for sure. Awesome light show on jackpot
#58 5 years ago
Yeah, the jackpot was cool when we were trying to diagnose the problem. I was pissed cause I wasn't playing it but rather cheating. Oh well. I hope it solves the issue.
Pins are expensive.
#59 5 years ago
Your original board is not a hard fix but if you dont feel comfortable doing it send it to one the guys on here it would have been alot cheaper than getting a new one or If interested in recouping some money id be interested in purchasing your old board pm me if interested .
#60 5 years ago
Sure, I sell it. PM your price please. Thanks. Tell gameon46 thanks, LOL.
#61 5 years ago
bigd -- Yr da Man bro .. Awesome help U gave Kholmes .. I've been tuned N ..
Kholmes , This Blue Police Flasher Kit Would lOok Killer on Top of yr HS2 bro .. I have 1
#62 5 years ago
B Rose, where'd you get that extra topper? That's sweet!
#63 5 years ago
PM sent ....
#64 5 years ago
Thanks man
#65 5 years ago
i just replaced the U20 IC chip in mine last week. Less than a dollar in parts and 20 minutes of work. Just fix the board! it's a lot cheaper and what have you got to lose?
#66 5 years ago
I put a new Rottendog board in Getaway today. Game is working perfect. Guess the original board went. Oh well, it happens.
#67 5 years ago
Good deal, been following along to see how things ended up...
#68 5 years ago
Yeah, it definitely was something on that old original board. Not sure, didn't go thru it. I am sure that a chip can be swapped out for a new one at minimal cost. I am not that tech savy, but as I said, someone that is familiar with this type of work could have it done in a few mins.
Game is great! No more changing bulbs over to LEDS with the power on. Expensive lesson.
$ 399.95
Pin Stadium Pinball LEDs
$ 175.00
Professor Pinball
$ 259.95
