For the Getaway diverter, how is everyone's folded lip sitting when engaged? When mine is open it doesn't create a flush transition with the rail. The folded lip sticks out a bit and the ball hits it as it goes around.
It should be flush against the metal ball guide that makes up the inside of the horseshoe loop. When you activate the diverter paddle by hand, does the coil plunger come into contact with the coil stop leaving the lip of the paddle sticking out into the ball path? If so, it sounds like your coil stop/ and or coil bracket under the diverter assembly needs to be adjusted to allow full travel of the paddle.
Should be able to loosen the set-screws, adjust the diverter shaft and re-tighten the set screws so everything is flush.
There isn't clearance since it is touching the left side of the ramp. I would need to bend the vertical ramp section it hits but before I do that I just wanted to know what was normal.
There is a tiny amount of adjustment in the mounting tab that fastens the vertical metal guide to the diverter assembly. Not much but there is a little. The screw that goes through the mounting tab has to be loosened and there is a lock nut on the underneath side I am pretty sure that will have to be loosened. Push the tab and metal guide to the left as far as it will go and tighten the screw.. Another option is to slightly elongate the hole/slot in the mounting tab to create a little more adjustment. A small round jewelers file could be used to elongate the hole, but don't do it to much.
It isn't a matter of adjusting the diverter, it is hitting rail when it swings open and isn't sitting flush. All I need to know is if it is supposed to be flush by design when it is open.
It should be flush, the ball should not strike the diverter paddle or anything else when making the entrance to the magnets; the smoother the ball travel the better as it enters the magnet cage.
This page was printed from https://pinside.com/pinball/forum/topic/hs2-diverter and we tried optimising it for printing. Some page elements may have been deliberately hidden.
