Picked up a HS last weekend for $650. Supposedly this pin was sitting in a basement or garage for the last 10+ years. The guy I got it from knew nothing about pins and was even amazed when I pulled the glass out.
The pin powers on no problem. Here are my current known issues:
1. "Adjustment Failure" upon power up. I researched this and it is an easy fix to put new batteries in. Going into service mode and scrolling through all the options then allows the game to play. (There were no batteries installed when I got the pin and no acid seen on the board). When I went to put in new batteries, the right most AA was too short for the opening. Upon closer inspection it looks like the connectors are missing a little insulator and some metal which would close the gap. The left and center battery positions look normal. I can see signs of a little acid wear in the area where that little insulator thing would have been.
- Possible fixes I've considered include simply bending the prongs in so the battery fits (in short term) or just buying a remote battery holder now.
2. LED displays flicker constantly. I had a pinball repair guy over the other day to replace flipper transistors on my LOTR LE. I had him take a quick look at the HS and he suggested replacing the entire power control board with a new Rottendog
- planned fix is to get the new Rottendog board. I've found one new for $85 plus shipping.
3. Music seems to work but no sound effects or voice. I have not trouble shot that at all yet. As I don't know much about board work or even how/what to test I'm tempted to find a new board I can simply just plug in. I don't see where Rottendog makes a sound board for Sys 11 but maybe I'm missing something.
- possible fix: find new sound board or listen (hopefully) to some easy solutions you may have
4. Numerous light bulbs out.
- plan to replace all lights with LEDs
5. LED scoring displays not centered in the backglass window
- plan to adjust the height of the displays by raising the entire panel (there are a bunch of washers on the hinge which look like they can be moved lower thereby raising the entire panel up a little which should work hopefully
6. Playfield wear
- short-term fix is to simply wax what I can without doing an entire 'shop' job of the playfield
- long-term fix is to install a new playfield. Sadly, the CPR HS playfields look to be already spoken for. If I cannot find a new playfield I may go ahead and perform my first full shop job
7. Ramp entrance: the little thin metal thing which connects between the playfield surface and the ramp itself seems to be pulled up a little.
- not sure what to do there. It seems like there is an adhesive that has come loose. Alternatively there may be an issue with the little set screw. I'm not sure exactly how that is supposed to be constructed so I'm not exactly sure what to do. Thus far the ramp shot can be made but there have been times that the ball does get interfered with due to this issue.
8. Beacon light missing
- possible fix: either find a replacement (if you know where, let me know) or put more of an LED police flicking light bar on top. I think that would be very cool but I would need to learn more about how I would go about wiring such a mod.
Sorry for the wall of text. I am VERY open to suggestions and help. This is my very first restoration project and, like I mentioned, I have not even done a full playfield strip and shop before. Ideally before everything is done I hope to have not spent much more than another $1000 (if I get a new playfield) and have a very nice pin to boot. I think the cabinet is in surprisingly pretty good shape except for the front. I may consider new decals but that is lower on my list of priorities.
Here are some photos:
