New! Dark mode!
(Topic ID: 260124)
HRC Delays?
By Nikrox2
9 months ago
  • 6 posts
  • 3 Pinsiders participating
  • Latest reply 8 months ago by Nikrox2
#1 9 months ago
Just picked this game up and so far so good. All working good and seems to play great. (The Roulette wheel did squeak a bit when rotating yesterday, but then that went way, so any tips on that would be nice) (Sometimes the ball will go into the roulette wheel, sit there until the game runs thru the solenoids, then the roulette wheel will start rotating and drop the ball, so thought this may be normal?)
This posting is in regard to some delay issues I'm seeing. First - when hitting the start button. It may take 10-20-30 seconds before the game starts. If I hit it more than once, I get added players of course...
Then when the ball drains, it counts all bonus', then it waits - say 10 seconds, before it kicks out the next ball.
Both of these sound like very little time, but when ready to start a game or shoot the next ball, waiting any amount of time seems like its forever.
Any one else have similar issues? I'm searching for a manual, but all else seems to be working fine..just these delays makes you want to move over to another machine while it's waiting...ugh
Any and all help is appreciated!
#2 9 months ago
Sounds like maybe a ball trough issue; balls getting stuck, balls not registering on switches etc...
I would start there! Maybe someone also has some other ideas.
#3 9 months ago
Possible trough divots.
#4 9 months ago
I'll check when I get home. When the balls drain, the points/bonus' are quickly added on, then it sticks on the last bonus screen..and hangs there for a while, then kicks out the ball.
Same as start up - it'll go thru diff screens on the display, even after hitting the start button, then for no reason, it starts the game up.
3 weeks later
#5 8 months ago
ok, I have an update. After I get my games in, I send the boards off to my "mentor" and he goes through them thoroughly, which usually eliminates 90% of any issues (then I "try" to handle the rest) I'm starting to "learn" the board work, but besides the physicality of doing it correctly, there's still that "knowledge" factor that I'm way off on, so maybe one day...we shall see.
Back to HRC -
Power Supply - Q3, Q4 & Q5 - reseated, cold solder joints and pads lifted all fixed, one resistor replaced, replaced fuse clips
Driver Board - Q1, Q2, Q12 and Q15 reworked previously hacked repairs, checked all transistors and caps
MPU - Removed battery's and installed NVram, cleaned up old flux
So now this thing is singing! No delays, from start to finish. Pretty cool game with all of the different screens and features. May go in the line up.
#6 8 months ago
I do now have to rebuild 2 pop bumpers - not only are the aprons a mess and chipped, but two of the 3 have broken "ring & rod" assemblies.
After that, this one is complete and ready to play!
$ 99.00
Arcade Upkeep
$ 65.00
Lighting - Backbox
Arcade Upkeep
Arcade Upkeep
$ 79.95
PinSound
$ 78.00
$ 6,200.00
Great American Pinball
$ 6.00
$ 86.95
$ 54.99
$ 40.99
Lee's Parts
$ 7.00
$ 37.00
The MOD Couple
$ 7,599.00
Gulf Coast Pinball, LLC
$ 4.49
$ 28.00
The MOD Couple
CzTV Mods
$ 54.99
$ 159.99
$ 12.95
$ 65.00
Texas Pinball
