(Topic ID: 132080)
How would you hang this?
By jardine
8 years ago
    #1 8 years ago
    Got this from a mate the other day...looks cool when lit and want to get it up.
    Looking to hang from the ceiling but how? Do I just get some chain, open up an end, use the loop to hook it in the holes?
    Any suggestions to make sure it holds tight from those that have done this sort of thing before, cheers.
    #2 8 years ago
    It should be on the wall?
    Why the ceiling?
    #3 8 years ago
    Not hanging on the ceiling...hanging from the ceiling, against a wall...hope that clears it up, lol.
    #4 8 years ago
    Good chain threaded Through hole will be fine. More importantly put good eye hooks into your ceiling joists/trusses etc. Dont rely on plaster fixing only.
    #5 8 years ago
    I think chain also, and........
    That is awesome!
    #6 8 years ago
    Thanks guys, I thought chain as well. Definitely will look for studs in the ceiling...I'll be stuffed if this falls.
    #7 8 years ago
    I would cut a thin piece of plywood smaller than the outer edges so its hidden, then screw the plywood into the studs wherever you want to mount it, then screw that Lego piece into it....unless you want it hanging vertical....go with the chains.
    #8 8 years ago
    You want wire rope or aircraft cable.
    #9 8 years ago
    I would thread eyebolts thru the hole in that mounting stud. Screw in eyebolts into the rafters. Then get the proper rated chain to hang it. Use small carabiners or screw gate locking hooks to connect the chains to the eyebolts such as the one below.
    d-shaped-screw-gate-locking-carabiner-hook.jpgd-shaped-screw-gate-locking-carabiner-hook.jpg
    This page was printed from https://pinside.com/pinball/forum/topic/how-would-you-hang-this and we tried optimising it for printing. Some page elements may have been deliberately hidden.
