(Topic ID: 161618)
How to troubleshoot a weak flipper?
By deeplennon1
  • 20 posts
  • 12 Pinsiders participating
  • Latest reply 4 years ago by Miguel351
#1 4 years ago
Hiya, I just bought a WCS over the weekend and the right flipper feels weaker than I'd like (though it can still make ramps etc.). Manually moving it it feels looser (more 'free') than the left.
Are there any steps I should take to diagnose/troubleshoot the problem before proceeding to my first major pinball surgery: a flipper rebuild?
#2 4 years ago
Unless there's something like a screw or mount that is obviously loose (and that can be re-tightened), you're probably just going to have to go and buy yourself a flipper rebuild.
Don't worry though! Resident expert Vid1900 has a most excellent guide that'll walk you through the relatively painless process of rebuilding them. Check it out here: https://pinside.com/pinball/forum/topic/vids-guide-to-upgradingrebuilding-flippers
Good Luck!
#3 4 years ago
no just buy the rebuild kit for all flippers. pinball life has the best deals. replace the bushings to as they do not come in the kits. i rebuild all the flippers on every game I bring it. totally worth it
#4 4 years ago
A "new-to-you" pinball is in unknown condition in my opinion. Therefore, a flipper rebuild would be where I would start.
#5 4 years ago
Along with the pawl, which is the likely culprit and which you'll get in a rebuild kit, you might consider ordering new flipper bats as well. The bats might be scored where the pawl grabs and, worse, might actually be split where the shaft meets the bat. I had the latter happen once. Sucks to rebuild and then realize the problem was actually in the bat.
#6 4 years ago
Before going all out on a full flipper rebuild, I would check the EOS switch. May just be out of adjustment. You can always rebuild later if you so choose.
#7 4 years ago
Quoted from rcbrown316:
Just had to chime in here to say that I can't believe I actually had to upvote Rcbrown on something...but he's right. I hate when that happens.
EDIT: Superbee has a good point, too!
#8 4 years ago
If you're going to buy a rebuild kit, take it apart first and see if you can get the plastic sleeve out of the coil. If not, add a coil on with that order.
#9 4 years ago
Quoted from SUPERBEE:
Thanks for the suggestion (and suggestions from all).
Not home yet so I haven't been able to look at it but your thought is that it's EOS switch connectors may be too close together?
#10 4 years ago
Quoted from deeplennon1:
Not sure how WCS is set up. Some are power open and some are power closed. Im sure someone else will chime in on this. Or go look at Vids guide to flipper rebuilds. It is excellent !!
#11 4 years ago
eos could be A problem but if it feels loose when you move it manually its likely the pawl. that and mushroomed coil stops are the most common things I have seen. also related, the solution for a preponderance of unnecessary chatter is to block beelzeboob....
#12 4 years ago
Thanks RCBrown for the tip to order bushings. Surgery occured this morning on the right flipper and the bushing turned about to be the culprit.
#13 4 years ago
Good thing ya checked. Playfield wear would have ensued
#14 4 years ago
nice! now only if I could train myself to stock these things. I always end up rifling through the several hundred pounds of used flipper parts to try and find a decent one to use as a temporary measure.
#15 4 years ago
And the worst quality. Soft metal and they don't even include the bushing in their kit.
#16 4 years ago
Quoted from o-din:
And the worst quality. They don't even include the bushing in their kit.
Most places have stopped including bushings in their kits. I always order a set when I order rebuild parts. I also keep 4 or 5 of both the Williams and the DE/Stern on hand for the random breakage.
#17 4 years ago
I added the part about the soft metal pawls that come in pinballlife kits . Pbresource sells a quality "complete" kit.
http://www.pbresource.com/rebuildkit.html#KT-WFLIP06
#18 4 years ago
Quoted from o-din:
its the same kit as marco. looks like steve young includes the bushings. still worth it. gonna start buying all of them there. yeah you get yelled at but you dont have to think!
#19 4 years ago
All I know is bought pinballlife kits in bulk at one time and have found it better to use the original pawl than put that weak thing on there. Same quality as the rubbers they sell. PBresource and Marco are the only places I order from any more unless they don't have it.
#20 4 years ago
Don't really need them yet myself, but I'm gonna add them to my yearly knick-knacky parts order from Marco when I'm at CAX in a few weeks. They always have great deals, free shipping, no tax, and sometimes even take off a few bucks to make things a nice round number.
Love those guys!
$ 159.99
Flashinstinct
$ 69.95
