Working on a 1981 Gottlieb Volcano and I noticed the left flipper is touching and rubbing the ball guide rail. It's really close and when the flipper activates, it's chewing into the rubber. I rotated the rubber to a new spot and after only a couple days of play there's another nick in the rubber. It's due for new rings but I don't want to put them on before solving this issue.
Flipper touches ball guide rail
I tried bending the guide rail away but there's only so much I can do without making it loose or having it bend away and looking stupid. Right now, it's fairly perpendicular to the playfield as it probably should be. It looks good visually for whatever I know.
Then I thought maybe there's an adjustment or some wiggle in the flipper mechanism underneath. Nope. Screws fit the holes really well and I cannot move the flipper assembly away from the edge of the rail.
Is this a common issue and what would be an acceptable permanent solution?
Thank you!
EDIT: Just realized that maybe the flipper bats need to rotated backwards. The rubber only touches when the flipper fully extends. What is the proper resting position?
EDIT 2: If the top edge of the flipper bats are supposed to be parallel to the ball guides, I'm screwed. They are already rotated somewhat down from this position (maybe ⅛" or more at the tip), so if I make them parallel as being discussed in other threads, the problem of interference upon extension is going to get worse.
