Ok, I was adjusting my flippers as I was getting a lot of airball when the flipper would hit the ball, so I loosen up nut holding flipper shaft in pawl, made my adjustments and proceded to tighten and secure the flipper shafts in the pawl assembly. Well I though they were tight, then playing a game they moved so, lifted up the PF and grabbed my socket wrench and really put my all into it when the threaded washer that holds the nut "snapped" in two. Now I was really putting some torque and it would not hold the flipper shaft. So had to order the piece I need from PBL $1.25 part so I grabbed a few. What is the trick behind tightening down the flipper shaft in the pawl assembly? I never had this difficult time doing it. Someone explain the trick so my flippers don't move and I don't break anything else? Thanks
