If you want to remove the microswitch and it's holder, grasp the switch and the white plastic part, wiggle side to side and pull. It snaps it.
To remove only the microswitch,use your thumbnail and slightly bend the tab in the upper right of your photo and rotate the switch toward the rear of the machine and downward. It will be held only then by one little plastic nipple on the white plastic part. Lean the switch to the side and it will come off.then to remove the rest of the button assbly from the cabinet, unscrew the black plastic nut securing the housing.
Wordy but you asked LoL
Thanx for the fast replys! Old plastic an mild violence scares the crap out of me, so i did not try that.
But now that i knew that i had to be a bit forceful it worked like a charm.
Thanx alot! It made my day.
/mima
This page was printed from https://pinside.com/pinball/forum/topic/how-to-replace-startbutton-switch and we tried optimising it for printing. Some page elements may have been deliberately hidden.
