(Topic ID: 231597)
How to replace lamp sockets that are in a bracket?
By swampwiz
5 years ago
  • 5 posts
  • 4 Pinsiders participating
  • Latest reply 5 years ago by swampwiz
    #1 5 years ago
    I have a few titles - Gottlieb's Outer Space & Hot Shot, in particular - where there are some lamp sockets that are affixed to a bracket. Although they seem to be in working order (although in need of some rust removal), I was wondering how to swap them out. The bracket seems to have holes whose diameter is smaller than the gross diameter, so I see no topological way to fit a new one in. I presume that the replacement part (for Gottliebs) is A2913 (http://www.pbresource.com/sockets.html).
    Here is an example of what I am talking about:
    http://www.enteryourinitials.com/images/cforce/cforce_bonus_lamps_start.jpg
    #2 5 years ago
    id replace the bracket with individual sockets for each lamp
    #3 5 years ago
    Quoted from swampwiz:
    You can't, unfortunately.
    If you want to replace them, you'll have to replace the whole strip with individual sockets. The 1-1/8" #44 socket should be the right one, if I remember right.
    #4 5 years ago
    Why do you want to replace the sockets-any rust is easy to remove-just soak in evaporust. Generally the issue is the grounding of the lamp holder to the bracket so I always solder the lamp holder to the bracket and that fixes issue permanently.
    #5 5 years ago
    Quoted from wayner:
    Sometimes these lamp sockets get a short that can't get fixed. I have such a short in a Bally Supersonic that has blown out an Alltek lamp driver.
    For Outer Space, one of the lamps was rusted shut (i.e., a lamp pushing down could not impinge the plug), but through application of a lot of WD-40 and some fancy pliers work, I was able to get it open.
    This page was printed from https://pinside.com/pinball/forum/topic/how-to-replace-lamp-sockets-that-are-in-a-bracket and we tried optimising it for printing. Some page elements may have been deliberately hidden.
