How to repair/reinforce plastic ramps?
(Topic ID: 203800)
By Wiggy
9 months ago
  • 10 posts
  • 8 Pinsiders participating
  • Latest reply 9 months ago by erak
#1 9 months ago
The left ramp on my WCS (up by the diverter) got some cracks in it and some plastic has broken off the diverter hole itself.
-- What would be the best way to reinforce the plastic where the cracks are so it doesnt get any worse?
-- Is it possible to repair the hole with some kind of epoxy? How durable would that be?
#2 9 months ago
Some strong tape.
#3 9 months ago
I'd choose 2-part epoxy putty. I repaired my Taxi spinout and my Pinbot vortex with it and it is stronger than the original plastic.
#4 9 months ago
Quoted from wayout440:
Never worked with epoxy when it comes to plastic. Do you need sand it afterwards to smooth the surface? Should one reinforce with fiberglass?
#5 9 months ago
I just picked up a stretchable clear vinyl patch.
Its a newer version, that sets clear and type with play in the material.
Its designed for patching inflatable tubes, and bouncy houses.
Reasonably thick, I believe it to be a good choice in ramp repair.
Ill be testing it soon, and see how it fares, but I believe its quick, easy, and does the
job without the glue mess, or brittleness, as all my glue repairs in the past
break over time.
Maybe you can find something like this by you.
Something like Clear Flex-seal Tape?
Anyone try a product like this?
#6 9 months ago
Just please don't use "Duct"tape. I have had to clean up more bad duct tape repairs then I care to mention...
#7 9 months ago
Quoted from Wiggy:
Yes, sanding smooth is recommended, unless you get lucky and the application is smooth. I used the marine fiberglass tape on the back side of the Taxi spinout to add strength. There were several tape repairs and a gaping hole in the back of the spinout, and now it's solid and durable.
#9 9 months ago
Short answer.
Dependent on location of the damage, industrial sheet metal steel trimmed to size and riveted with small washers (if required). This is after using a 2 part epoxy injected into cracks for sealing purposes (note: this is only effective on older ramps made of butyrate, as you need to use other solvents for PETG). This method works for non-edge areas as well, but I prefer a thin polycarbonate patch. Proper preparation is required, and part/ramp must be removed from the game.
Owners/operators have been making their personalized protectors for a very long time in periods before reproduction injection molded and vacuum formed ramps were available, including before Cliffys (which he started around 1995) or equivalent around 1985. If done correctly, the protector will look as though it was factory designed. It requires patience, cutting, and fitting. A critical step is testing chemical interaction for color changes.
#10 9 months ago
^+1 Yup! This is the right way if you want your pin to still look pretty much factory. And not all hacked up with epoxy or sheet metal. And also to not cloud up those nice clear ramps.
$ 69.95
€ 40.00
$ 200.00
Professor Pinball
$ 129.00
LED OCD
