Wolvie is pretty easy, theres 2 screws on his back. You may have to pull the bottom right pop bumper cap to get to them. Magneto is much more of a task. You need to pull both ramps then remove the plastic plate he sits on.
Quoted from Thrillhouse:Wolvie is pretty easy, theres 2 screws on his back. You may have to pull the bottom right pop bumper cap to get to them. Magneto is much more of a task. You need to pull both ramps then remove the plastic plate he sits on.
I took the 2 screws out of Wolverine and didn't see anything else attached but he's still stuck. Maybe I need to pull harder on him?
Quoted from ryandimx:I took the 2 screws out of Wolverine and didn't see anything else attached but he's still stuck. Maybe I need to pull harder on him?
Why are you trying to remove the figures? There is a large solid metal piece inside of Wolverine that goes up through him. Is this an LE? If so, there is also a bulb inside him that may have become stuck. You could also remove the assembly and pull it up through the playfield. There is a connector for the switch and four nuts that need to be removed. As always, take pictures as you remove things.
Quoted from judremy:Why are you trying to remove the figures? There is a large solid metal piece inside of Wolverine that goes up through him. Is this an LE? If so, there is also a bulb inside him that may have become stuck. You could also remove the assembly and pull it up through the playfield. There is a connector for the switch and four nuts that need to be removed. As always, take pictures as you remove things.
Yes it's an le.
Putting a utility belt on Wolverine to prevent further damage and Magneto is getting a light mod.
Wolverine came out after some persistent rocking back and forth.
This page was printed from https://pinside.com/pinball/forum/topic/how-to-remove-wolverine-and-magneto-figures and we tried optimising it for printing. Some page elements may have been deliberately hidden.
