Protect playfield paint and use small flat screwdriver to pry up and it should just raise up and out.
Sometimes, there are holes for it that go all the way through to the other side of the playfield. If that's the case, you can tap it out with a roll punch.
If you have to pry it up, I'd first try a small pry bar.
However, I try to avoid pulling those wire guides off the playfield unless absolutely necessary. Sometimes they are barbed and can cause damage when coming out.
Quoted from transprtr4u:Ball guide wire behind the flippers?
Know there was a post about this , however cannot find it.
Proper name for those is Biff Bars.
Serious.
This page was printed from https://pinside.com/pinball/forum/topic/how-to-remove-the- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
