I recently bought a Williams Black Knight whose batteries leaked, and unfortunately the blue fuzz dropped onto the driver board underneath onto a few components, one of which was the flipper relay. Somehow the corrosion got inside and I can see it damaged the parts inside the plastic cover. The other affected transistors on the board were easily removed and replaced.
The rest of the board is good, I just need to remove the relay and solder in a good one, but I cannot seem to desolder this one completely enough to remove it. The lugs are almost as wide as the through holes and seem to allow just a little solder to remain between the two, even where it looks like it was all removed under a magnifiying glass. I'm using a Hakko desoldering gun with a 1.5 mm tip, what should I be doing differently to get this damn thing removed?
