(Topic ID: 162472)
How to remove black marks on playfield
By Collin
2 years ago
  • 24 posts
  • 8 Pinsiders participating
  • Latest reply 2 years ago by Syco54645
There have been 8 images uploaded to this topic. (View topic image gallery).
#1 2 years ago
I'm back to work on my Grand Slam rustbucket project, and seem to have the election issues mostly figured out. However, I'm struggling to get this playfield clean.
These blacks marks haven't come off with Naptha or Novus stage 2. Any suggestions for what might get this playfield cleaned up?
#2 2 years ago
Those pics don't enlarge enough to see the surface detail.
Is it heavy ballswirl?
Can we get a focused close up pic of a white area? (put your cameraphone in the mode with the "tulip flower" so it can focus up close)
#3 2 years ago
Sorry about that; I've added a few more pictures, that hopefully give better information. I'm really not sure what it is, which is a big part of why I'm struggling to figure out how to deal with it.
#4 2 years ago
Maybe it's mildew actually eaten into the lacquer (it sure does not look like ball swirl)
Under the apron, try alcohol and magic eraser.
#5 2 years ago
It's all over the heavy traffic parts of the playfield, but not the mylar areas.
This game was under a leaking roof, and I don't think water sat on the playfield, but the game has been subjected to some moisture
#6 2 years ago
There's nothing under the apron that won't come up pretty easily with Naptha
#7 2 years ago
Quoted from vid1900:
I'm sad to say, that seems feasible given the amount of water this game was subjected to.
In your experience is it feasible that would happen only in high-traffic areas?
#8 2 years ago
The Mylar probably protected the lacquer from any mildew attacking it.
Is there any mildew under the plastics?
#9 2 years ago
Not sure if this helps, but this is what I see under the right sling before attempting to clean.
I cleaned under the left sling, and the lacquer is plenty yellowed, but I don't know that I necessarily see mildew there.
I'm wondering if the lacquer finish has more cracks in the high-traffic areas that let the milder get down into the paint/wood.
#10 2 years ago
Just looked at the plastics which I pulled off the game a while back; they definitely have mildew on the top of them.
#11 2 years ago
I'm with Vid1900. That looks like mold or mildew. That has attached to the ball swirls. The tops of the flippers are also effected.
#12 2 years ago
Thanks for the feedback. Working with the conclusion that it's mildew, what are my options? Off the cuff, I can only think to either part it out (which is what I hoped to avoid by buying it,) look for another playfield, or just finish shopping it out and play it knowing I'm stuck with an ugly playfield.
I'm assuming the mildew likely goes through to the wood, right? i.e. with magic eraser and alcohol, I'd likely be unable to get the mildew off without taking substantial paint?
#13 2 years ago
Quoted from Collin:
Depends if the paint binder is edible by the mildew.
Try the magic eraser/alcohol in an out of the way spot and see what happens.
#14 2 years ago
I'd be inclined to say try a bit of tilex or bleache-white on a q-tip in an inconspicuous area to test for color fastness. If that is mold/mildew, I really can't think of any other way to remove it.
#15 2 years ago
There is a product called MoldEx, although it is water based. As a last resort it will kill the mildew. ["Do not use laundry bleach"].
#16 2 years ago
I tried that, and it's definitely removing the mildew with only a couple quick wipes!
I'm getting a bit of yellow on the magic eraser, which means I'm cutting some of the lacquer off, right?
If I do this gently to remove the worst of it, should it be playable if I keep the playfield waxed? Or should I really clearcoat it before playing? It's a game that, for the time being would be staying in my home, and see light play (Possibly less than 100 games per year)
#17 2 years ago
Quoted from Collin:
Depends on how much wear is already on the playfield.
A new clearcoat would be the best, but clean it up and see where you are at.
Quoted from Collin:
Yep, a lot of the times in sunlight it looks almost orange.
#18 2 years ago
Okay, so I tried the alcohol and magic eraser in a couple little spots, and think I wiped up a fair bit of the residue with a paper towel. Around the edges of where I was working, there's a bit of a white, kinda chalk-y looking haze. I take it that means I'm doing something wrong?
#19 2 years ago
The haze is normal.
It's the magic eraser residue.
Keep wiping it up while it's still wet, don't let that crap dry on the playfield.
#20 2 years ago
Quoted from Collin:
ME leaves that after you use it I think
#21 2 years ago
The magic eraser actually gets slowly used up, just like a pencil eraser. The white residue is awful to clean-up, it always seems to haze on me in bad spots, normally when I put on too much alcohol and the liquid gets away from me.
It is the main reason I almost never use a magic eraser, I only use it as a last resort on a playfield that nothing else will work on.
#22 2 years ago
I always assumed the white stuff was residue from the soap in the ME? I bought some cheap Walmart ME that didn't have much soap and I didn't get the residue as much...
#23 2 years ago
Magic Erasers are just melamine foam, I am not aware of them having any soap product in them.
Do a search for melamine foam to get a better idea of the products history. My memory is that they work just like a pencil eraser, by mechanically removing material while the foam is also consumed/covered by the material that is being removed.
#24 2 years ago
Quoted from mg81:
They are basically a 2000 grit sand paper equivalent. I was always told the white was lacquer that you had removed and that is why it hardens when it dries. I do not end up with the white residue when I use it on my counter tops or walls after my kids draw with a crayon.
$ 16.00
Yorktown Parts and Equip
Displays
PinballSolutions.eu
€ 3.95
Multigame
Pinball Photos
$ 180.00
Pinball Customs
$ 229.99
$ 7,299.00
Flip N Out Pinball
Pinball Photos
$ 69.99
$ 999.00
$ 5.00
Doc's Pinball Shop
