(Topic ID: 256766)
How to remove a broken coil sleeve out of a coil?
By fossmin
1 year ago
  • 13 posts
  • 12 Pinsiders participating
  • Latest reply 1 year ago by silver_spinner
    #1 1 year ago
    Any tips?
    #2 1 year ago
    Ive actually have used a drill . A bit that is same size as the coil opening. The new sleeve will be tough to get in . I usually put a little mill wax on it and goes right in .
    #3 1 year ago
    Jamb a tiny screwdriver between the coil sleeve and the coil. Tap it in with a hammer and crush the sleeve on itself. Then pull it out.
    #4 1 year ago
    Use a (yellow I think) nut driver and hammer it out
    #5 1 year ago
    If the inside of the coil is chewed up or warped I would go ahead and replace the coil and sleeve.
    You should not have to force a new sleeve in.
    #6 1 year ago
    If the coil sleeve is metal forget it, buy a new one.
    #7 1 year ago
    It was a plastic sleeve. Once I folded some of edges towards the middle, the yellow nut driver pushed it right through with a hammer.
    #8 1 year ago
    Be sure to ohm out that coil, if excessive heat caused the original sleeve to become damaged the coil might be bad and need full replacement.
    #9 1 year ago
    Quoted from fossmin:
    If the coil is swollen inside, better to just replace the coil too, while you're in there.
    #10 1 year ago
    Quoted from jeffc:
    Yes, use a 5/16" nutdriver to pound out the bad sleeve.
    #11 1 year ago
    Just use another sleeve works very well
    #12 1 year ago
    It’s been a while, but if you have a letter drill blank set a letter x or y drill blank fits nicely in a coil to tap a sleeve out
    #13 1 year ago
    pound out with nut driver . works well. Start with yellow (5/16) and when end of sleeve is at coil surface, use the green (3/8) nutdriver to knock it out of the coil. The yellow will actually fit inside the coil sleeve after pounding and get stuck if you keep at it, so you may have to switch it as it is flush with coil entrance..
    the green is the same circumference as the sleeve so it rests against the sleeve's edging as its pounded out.
    you cant use the green from the start as it will slip off the edge of the sleeve.
    $ 49.00
    Pixels Arcade Games
    $ 115.00
    $ 259.99
    $ 19.99
    Bent Mods
    $ 19.99
    $ 40.00
    $ 69.99
    $ 12.00
    Metal-Mods
    $ 159.00
    $ 8,399.00
    Classic Game Rooms
    $ 5.00
    Filament Printing
    $ 144.00
    Lighting - Backbox
    The MOD Couple
    $ 3.50
    Various Other Swag
    € 22.00
    YOYOKOPTER MODS
    $ 28.75
    The MOD Couple
    $ 69.99
    Pinball Photos LLC
    $ 90.00
    Lighting - Under Cabinet
    $ 4.49
    $ 14.95
    $ 139.00
    Sparky Pinball
    $ 73.99
    $ 9.99
